Question about Dryers
Zanussi tumble dryer TC 7103 S The tumble dryer has started to cut out and the water full light comes on but the water containers has only a small amount of water in it. It wont switch on again for about 15/20 minutes and then it will only work for a couple of minutes and cut out again. now we have discovered if we put in only 1 or 2 light items it will work ok
Posted by billy boyo on
  • taz_uk Apr 17, 2009
    I have the same problem with the Zanussi TCE 7127 W
  • derry1 Apr 26, 2009
    machine cuts out mid cycle with water full indicator light on. Won't start again for 30 minutes.
5 Related Answers
Timon90
Timon Gr?nlund
  • 126 Answers
SOURCE: Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Posted on Jan 25, 2008
Anonymous
  • 101 Answers
SOURCE: Zanussi Condensor tumble dryer does
Check the Thermostat.
Posted on Apr 21, 2008
Danny
  • 160 Answers
SOURCE: zanussi condenser dryer tc 7103 is not heaing up
either heater or thermostat at front,, my guess is the thermostat.... but test the hear 1st if able to..
Posted on Jan 04, 2010
Anonymous
  • 213 Answers
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: I HAVE A ZANUSSI TUMBLE DRYER TC 7103 W, ELEMENT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 20, 2010
I HAVE A ZANUSSI TUMBLE DRYER TC 7103 W, ELEMENT SEEMS FINE, THERMO ALSO FINE BUT STILL NO HOT AIR BEEING CIRCULATED
heatman101
Aug 20, 2010 | Zanussi TC7114W Electric Dryer
Zanussi TC7114W Tumble Dryer manual
Just click here for the direct download from PDF : TUMBLE DRYER TC 7114 W TC 7114 S
No websites or forwarding, that is just the manual from factory support website.
Vote the solution if this is what you are looking for
Sep 22, 2008 | Zanussi TC7114W Electric Dryer
Zanussi condenser dryer tc 7103 is not heaing up have ceaned all the fluff from the front but no different
Jan 04, 2010 | Dryers
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Water leak on Zanussi tc7102 dryer
I had a similar problem. There is a 'o' ring on the plastic part that keeps coming out. This 'o' ring is not big enough, you need to replace it with a thicker one, preferably one made from a harder material.
Feb 28, 2009 | Zanussi TC7102W Electric Dryer
Tumble dryer fault
usually this is a sign the felt bearings on the drum, or the roller bearings under the drum are worn and need replacing
felts and rollers should be visible once you open the case
check the rollers turn freely, check the felts are not worn through
replace both rollers or both felts if one is worn
Jul 01, 2008 | Zanussi TC7114W Electric Dryer
Common faults -
Feb 24, 2008 | Dryers
Dec 30, 2007 | Dryers
Dryers Logo
117 people viewed this question
Top Dryers Experts
Marvin
Marvin
Mike
