You must try to crank it by hand ,remove spark plugs so there will be little compression and then try to turn the motor it should turn without to much force this will indicate the motor has not seized when hooking up a jump start do not connect both leads directly to the battery ! the red + lead should connect to the red+ on both batteries but the neg lead - should not go to the battery post but to a ground usually directly to the metal engine cover or you can damage the battery !
SOURCE: how do we start a yamaha 1998 xl 1200 wave runner
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
SOURCE: 2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
SOURCE: I have a 2002 yamaha waverunner xlt 1200. it will
hate to break it to you. carbs need to be rebuilt. the new fuel doesnt bode well for the carbs, clogs a really small filter and jets in the carbs
just had it done for the second time for a cost of $550/each time
