Twain is the scanner interface program on the computer. Something is missing from the install or the XP system software. Double check to make sure you're installing an XP-compatible version of the scanner software. The program for newer versions of Windows likely assumes the presence of some software components that may not be there in XP unless the install program puts them in. Without those missing pieces, Twain won't load properly.
SOURCE: I have lost my canon
Click here to download the drivers for your cannon scanner.
Hope this helps! Dont forget to rate the solution!!
CreativeTECH
SOURCE: I have a CanoScan LiDE 200 scanner attached to my
Same problem here (MX700 scanner, using MP Navigator EX). It really is a pain, isn't it?
If you don't need the date-specific filenames immediately, you can modify the filenames later, in a batch process: http://maketecheasier.com/2-ways-to-batch-rename-files-in-os-x/2009/05/16
SOURCE: My acer crystal eye webcam
Maybe you instal wrong driver ?
try to reinstall windows, if still same error, your webcam maybe broken.Thx
SOURCE: need download canoscan lide 200
Since you don't clarify your op. system I suggest you to go to this official link and choose your op. system and language and download the drivers for your scanner.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
SOURCE: need canoscan lide 200 drivers
hi,
Just download through this link:drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/CANON/Canon-CanoScan-LiDE-200-Sca
Hope it helps.Thank you!
