Question about Creative Labs Nomad MuVo MP3 Player
Problem turning on
Ok my FIRST problem was the mp3 player automatically turning itself off after a few seconds of playing unless the battery power was almost gone, or when it hit certain songs, so I installed the firmware as recommended in a couple other similar problems off of the creative site, and now the mp3 player won't even turn on! what happened? light only turns red, and does not play, worked 1 day ago.
Posted by THELAWLORS on
5 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: Firmware Problem + Can't upload new Firmware
http://www.anythingbutipod.com/forum/showthread.php?t=10960
go here
Posted on Feb 21, 2008
Anonymous
  • 12 Answers
SOURCE: creative zen v problems-frozen
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
-bananaboy101
Posted on Mar 25, 2008
ayotan
SOURCE: Creative Zen Nano Plus FROZEN!!!
here is a fix if your creative zen nano plus just hang on the creative logo when you turn your player on.
download, Creative ZEN Nano Plus firmware.
you can find it at the creative website, download section.
double click the file you just dl'ed, now make sure your
zen nano player is already connected to your pc when you run the file. it may take a bit of time before your pc can detect your zen nano be patient, a window prompt will soon appear asking if you want to update your firmware with the one youve just dl'ed.
now, dont worry if the firmware is the same as the one already
installed in your zen nano, just continue with the update.
you can also check the box in which there is the option of also formatting the drive. ( note: all files in your zen nano will be lost)
after the firmware is flashed you can now play and transfer files to your zen nano plus.
Posted on May 09, 2008
Anonymous
SOURCE: Zen Sleek not recognized by firmware: not connected msg
I had the same problem with zen v (video). My pc (Xp s. pack 3) recognized the player in device manager, but reloading firmware failed, as that small app. was still asking me to connect it.
I used my friend's pc Xp sp2 with automatic updates disabled and eventually loaded firmware into my zen using ' mp3 player recovery tool' from creative website http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp? (,because that small application - firmware pcfw_l22_1_32_01 didn't recognize player again.
Posted on Nov 08, 2008
Shayne Schecht
  • 146 Answers
SOURCE: Creatve Zen freezing at rebuilding
Try using a different computer or a different USB cable. It is possible that the Windows mass storage driver is having issues. You may also want to try to download the newest software from Creative and install that. You may also want to try to plug it in and then press the reset button and see if it detects it when it restarts.
Also try putting an SD card into the expansion slot and see if it detects it as as mass storage device.
If none of the above work and it is still under warranty (less than 90 days) I would send it to Creative for repair or replacement. If it is out of warranty, Creative's repair costs may not make it worth fixing. When my out of warranty player needed fixed they were going to charge 125 USD and I only paid 200 USD for it about a year earlier. When it finally got to be too hard to deal with I opted for an iPod. Granted they are more expensive but the support is better and the warranty is 1 year.
Cheers and best wishes.
Posted on Jan 01, 2009
My Sansa clip mp3 player doesn't get detected
Trying:
1. Update Windows Media Player 11 for computer
2. Get in Device Manager, right click on icon device and anable it.
Good luck
Jan 22, 2010 | SanDisk Sansa Clip MP3 Player
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Even when the battery is fully charged(3.6v) the player turns off by itself in a few seconds. However, when connected to a PC, it continues playing normally.
Dec 12, 2009 | Transcend T.sonic 610 MP3 Player
My SDMX1- 256MB can turn on but doesn't play and turn itself off
dont know what "hall" is, and im guessing the battery isnt dead---might need to format it
Aug 12, 2009 | SanDisk SDMX1 MP3 Player
My jenson mp3 model smp-2gbl wont stay on
i have a jensen model# smp 2 GBL it wont play it comes on for a second then turns off. I took out the music put in new music then it played for 5 minutes then turned off and does the same thing again. I put in alot of new batteries that dont work either can you help me
Jul 09, 2009 | Jensen SMP-115 MP3 Player
JWIN mp3 player
try holding the play button for 10 to 20 second it's probably come on.
Jun 29, 2009 | Jwin MP3 Player
Help!
To the op, you might need to switch it back to MSC mode from MTP mode. You might not be able to play the DRM protected music in MSC mode, but you'll be able to access all the rest.  1. With the unit on and not attached to a computer, press the Power/Menu Button briefly once or twice so the menu is shown.
2. Scroll down to Settings then press the OK button (round shaped, centrally located) to enter the submenu, next scroll down to the USB option and press the OK button to enter its submenu, highlight MSC, then press the OK button. After the MSC option is enabled, hold down the power/menu button until the unit shuts itself off. Now plug it back into the computer.
(Now you should be able to find some files to delete. Enter any folders/directories if necessary to find files to delete.)
Unless you have bought and downloaded to your unit protected music from online music stores, you might find it more useful to keep the MSC setting instead of going back to the MTP setting.
To the second poster, you likely downloaded a scam file.  It's sometimes disguised as an mp3 file but it's really likely to be a wma file that has web links that automatically execute when played in Windows Media Player.  Your mp3 player errors when accessing it. Just delete the suspect file(s).
Otherwise you could reformat it or maybe upgrade the firmware. Right-click its icon in My Compter for a popup that allows a format.  Use FAT32.
Sep 01, 2008 | SanDisk Sansa m230 MP3 Player
Powers down automatically
Have you tried to update the firmware on the device..that would help..
Feb 13, 2008 | SanDisk Sansa m230 MP3 Player
Coby MP-C582 Will not turn on
Check on the side of the player and make sure it is not locked that was why ours would not turn on. Once I unlocked it worked fine
Dec 24, 2007 | Coby MP-C582 MP3 Player
How to unfreeze mp3 player
Try Holding the Power Button for 20 sec for a Power Reset of the device Turn on the Player ,hold the Power button for 5 sec.
Oct 03, 2007 | SanDisk Sansa e250 MP3 Player
Creative Labs Nomad MuVo MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
