Adobe illustrator will throw run time error while working on an iamge file.wat may be the reasin for this
RybtuneMiecrosoft Visual C++Runtime Library
Runtime error
Program: This application has requested the Runtime to terminate it in an unusual way.
It says to contact the application support team for more information.
If you can't figure out exactly the reason why and wish to work with your software, you can uninstall and reinstall it again. You must delete all leftover files from program files and from the registry editor. Want less effort to do? Use Revo Uninstaller to do the work. Search from google, download and install.
SOURCE: Adobe illustartor shows run time error
How large is the file? How much system memory do you have? What is the source of the file? Are you able to open the file on a different computer?
SOURCE: runtime error
Does the Program issue you the name of the suspect runtime library at any point? If it does, go get the latest version of the runtime from the NET, in a searchengine type the name of the file+ext. download and then copy it in the same direrctory (folder) as the one on your system now. NOTE: I would FIRST rename the one on your system as <currentfilename.current_extention>and then add .OLD to it.
SOURCE: excel not working upon start up
Make sure that you have all the updates for Microsoft office by visiting Mocrosofts website and download the hotfixes.
If that doesn't work
Try uninstalling office and reinstalling to fix the problem.
SOURCE: Runtime error
Method 1: Clean Boot with Only MoSearch
loadTOCNode(2, 'resolution');
The Mosearch.exe (Microsoft Office Search Service) and Mosdmn.exe (Microsoft Office 10 Search Filter Daemon) Startup items may be conflicting with some other program (or programs) running in the background. Therefore, clean boot your computer with only MoSearch selected on the Startup menu to determine whether this program is the source of the conflict. To do this, follow these steps:
If the error message cannot be reproduced, this indicates that MoSearch is conflicting with some other program or programs running in the background. Follow these steps to locate the conflicting program:
NOTE: In Microsoft Windows Millennium Edition (Me), leave the *StateMgr check box selected as well.
If these steps don't help you find and eliminate the conflict, proceed to the following method.
Back to the top
Method 2: Uninstall the "Support for Fast Searching" Feature
To uninstall the "Support for fast searching" feature from all Office XP products that are installed on your computer, follow these steps.
Note This applies only to computers that are running Microsoft Windows 98 or Microsoft Windows Millennium Edition.
When I am trying to open CS2 adobe illustrator a window pops up saying
Runtime Error!
Program..rator Cs2/suport File/cpntents/windows/illustrator.exe
This application has requested the runtime to terminate it in an unusual way.Please contact the application support team for more information.
I have the exact same problem.
