Bosch Fridge Freezer KUR15444GB 01 Thermostat
This picture shows the device that controls the temp. There is a small capillary tube that responds to the temp inside. Make sure it is not kinked or broken.
SOURCE: Samsung RS21w USA style frige freezer panel problem
hold down the 2 lower buttons for 5 seconds to unlock the display panel
SOURCE: My Bosch Fridge Freezer Model
Hi thanks for the question. I would pull fridge away from the wall . remove back panel . clean all coils . thanks the appliance doc
SOURCE: Fridge is freezing things when temperature guage is on
check damper control or refrigerator door (ajar)
SOURCE: Fridge freezes
think you are placing too many things at the back of the wall. That is where the cool air is coming from. Try not to choke up the back.
Yes you have a bad relay on your compressor.Remove the rear panel and take off the relay on the compressor shake it.If it sounds fried then you need to order new on .Just give your model# to your local parts depot and ask them to order you a new compressor relay hope i fixya:)
