Question about Dryers
Sears kenmore dryer model number 110-66912692. Dryer has been slow to dry clothes for a bit now. This morning it stopped drying all together. I called to order a heating element and the guy asked me if it was the thermostat or the element. How could I figure out how to find the broken part...and is there a diagram of the inside of this dryer so that I could access the element and the thermostat? I could wait for my husband to come home from work....but I think I can handle this one. Thank you
Posted by marci1023 on
  • olgfer Oct 20, 2008
    Same problem as above
5 Related Answers
Anonymous
  • 213 Answers
SOURCE: Kenmore 70 Series Electric Dryer Won't Dry.
the vent where the air from the dryer leaves the house is blocked. if the air cant get out at the proper rate of speed the clothes cant dry properly. the vent needs to be cleaned out. not just the part be hind the dryer but all the way to the outside. if you need someone to do this for you, most chimney sweeps will handle this problem
Posted on Nov 26, 2007
Anonymous
SOURCE: Kenmore 110.64962300 Elite King Capacity dryer
the power supply to the mobile home may not be strong enough {if generator run gen not big enough] {if powered by lead to power source lead to long or not big enough} {voltage drop}
Posted on Feb 21, 2008
francis rivero
  • 958 Answers
SOURCE: Dryer not heating
normally, it is the thermal cutoff switch. test this part for continuity and if there is non, then that is your problem.
tnx 4 using fixya,
drcool
Posted on Sep 29, 2008
Anonymous
SOURCE: No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Posted on Nov 11, 2008
mike cooksey
  • 163 Answers
SOURCE: Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Posted on Mar 09, 2009
Dryer will not start
might need a control broad if you know how to check it out ,if u still got the mannual that came with the dry it will have a troubleshooting page you can read it will help you out are calll a appliance repair man ok
Jun 10, 2017 | Kenmore Dryers
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
Stops before clothes are dry
Sounds like a motor going out . You need to replace the motor .
Jun 29, 2010 | Kenmore 65924 Electric Dryer
Problem with Dryer Timer or heating element
The heat cycle must be working for the timer to advance in the Auto Dry setting.
Your heating element and or high limit thermostat is bad.
We need a complete model number to be more specific.
May 31, 2010 | Kenmore 600 6965 Electric Dryer
DRYER DOOR WILL NOT STAY CLOSED WHEN IN USE
Most likely the receptacle that the door latch goes into is broken. Go to local appliance parts dealer with model number and buy the $5 part, or order through Sears Parts Direct online.
Jun 13, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer will not turn off
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
97 people viewed this question
Top Dryers Experts
Marvin
Marvin
Mike
