Usually a flashing power light on a rear projection TV means a bad bulb, try replacing the bulb. Also try unplugging it for 10-15 minutes, then come back and plug it in and try again. Also if its been a long time since its been serviced it could be dust buildup causing overheating, do you hear the cooling fan running? It could also be a failed cooling fan. Generally the first thing i do with projection TV's is clean them, clean all the vents, pull the bulb out, clean out the cooling fan and bulb housing, and then try a new bulb. If that doesn't fix it then its a bigger internal problem and there is no quick fix but have it serviced.
SOURCE: SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
SOURCE: Sony KDP-65S550 red light keeps blinking
How many times is the LED blinking in between pauses? that is possibly a error code if you can determine the number of blinks.
SOURCE: sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
SOURCE: Sony Wide Screen Projection TV KP-51WS520
I had the same problem. blinking 9 times, pausing, 9 times...... remote would not power the tv on. after five minutes of pressing the remote it finally would. after turning it off you would have the same problem. sometimes a half hour of pressing remote in every which what way. finally left the tv on for three days and would mute at nite to go to bed. didn't think that was the best way so turned it off and it never turned back on. checked all the forums and found out it was the g board. unfortunately, you cant buy the whole g board anymore. if you take the back panel off the tv, on the lower left corner is where the g-board is. there are 3 little things to unplug and two screws (phillips head) in the middle of the g board. its simple to figure how to take it out. go to the sony direct parts website. the part # is A1054157A for the g board. since they dont sell it anymore they have a phase 3 program where you send in your old g board and they repair it for 64.95. it'll cost about 8 bucks to ship it to them. better than the 400 bucks the tv guy wanted. address is sony customer satisfaction ctr. , materials door 27H, mount pleasant, PA 15666 there number is 866-748-8272. call first and they give you the step by step instructions what to do. after tax and shipping it came out to less than 80 dollars.even came with a warranty. got it back in a week, popped it in and just love turning the tv on. anyone can do it.
SOURCE: sony kp-51ws510 tv blinking light 6 flashes on timer/standby
6 blinks on your model means the +5V line is either overloaded or shorted on the A or B board. You can get replacement boards at the following link and they will assist you in determining which board of the two you actually may need.
http://servicemanuals.vstore.ca/
