Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password
You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
In order to connect NETGEAR router to the Internet you would have to
follow certain steps. First you would have to plug the NETGEAR router
into the electrical socket and then connect the DSL or cable modem to
the Internet port of the router with the help of an Ethernet cable. With
the help of a separate Ethernet cable connect your system to the
router. Then open your Web browser and type the necessary address in the
address bar. After that when the log-in Window appears you would have
to enter the specific username and password. Click on the Setup Wizard
and then on yes. By doing so it would automatically detect your Internet
connection type, Finally, configure your router by providing the
necessary ISP, username and password.get more information for Netgear Router Configuration
Hope this helps you.
Good Luck!
1.Launch your Web browser and then type 192.168.1.1 in the address field. Click "Enter." 2.Click "Basic Settings." Input the configuration information given to you from your ISP in this screen. The settings not given by your ISP can likely be left at their default value. Click "Apply" before navigating away from this screen. 3.Click "Wireless Settings" in the menu on the left side of the screen. Enter or select the appropriate settings in the Wireless Settings dialog. Select the appropriate Security Options, then generate the security key. Click "Apply" before navigating away from the Wireless Settings dialog. 4.Reboot the router for the changes to take effect.
Good Luck, Jopica123
