SOURCE: Fridge/freezer gets cold, but won't stay cold.
Service:
http://mrappliance2.reachlocal.net/land/
http://www.sears.com/sr/service_order/so_productinfo.jsp
DIY repear and diagnosic help:
http://www.acmehowto.com/howto/appliance/freezer/freezer.php
http://www.repairclinic.com/0047_3.asp
http://www.fridgedoctor.com/
SOURCE: Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
SOURCE: Kenmore Upright Freezer Alarm
1. You can hear the compressor running.
2. The temp setting you turn the thermostadt to starts and stops the compressor.
3. Look in your manual for a reset button and the location.
4. If you are familiar with a meter, grab the manual and check it it. But I doubt it is the resistance.
5. Sounds like a bad motor or low freon. If you have a lot of food in it, and the above didn't work, bite the bullet and call a repairman, although it sounds like much of the food is past saving if it is really defrosted.
If the freezer was stored and not running for 7 years it may have lost coolant. Since the compressor is running recharging the coolant may fix the problem. Hot compressor might indicate low coolant since its motor is immersed in it.
SOURCE: Whining sound from motor on Frigidaire upright freezer
Hi: It sounds like you bought a frost free freezer as it has a fan. The fan will come on to circulate the air. It will not necessarly run continuosly. The noise is most likely coming from the fan. I sold Frigidaire freezers for years and they are noisy compared to a refridgerator. If you think it is louder than it was when you bought it, I would replace the circulating fan. Also look at the back wall for frost as it could be a bad defrost heater blocking it with ice. Most likely just the fan though. Since it's in a detached garage,and you won't have to put up with the noise inside your house, it could run a while before failing. The fact it's getting cold is a very good sign.Also as you asked 2'nd, a freezer is ok in an unheated garage. Don't put a refrigerator in there. Unless It is a Whirlpoll Gladiator that is designed for such applications. Use www.searspartsdirect.com to find out where the fan is if you feel it is necessary to replace it. Its not a tough job if you are handy. Their shipping is expensive so you might want to buy it locally.
