2003 Acura MDX Logo
Posted on May 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 02' mdx won't come out of park, keep blowing a 20 amp fuse. This fuse controls the Cruise, break lights, memory seat, horn and linkage. I have to manually delink. I have unhooked the comand start which had been in since new but no go. Why am i blowing this fuse?
Anonymous
Level 2:
Scholar:
  • Expert 87 Answers
  • Posted on May 17, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
87
Questions
Helped
81668
Points
317
Here is an idea, when do you blow the fuse key on, key on engine running, key on engine running hitting the break pedal? Try and get the key on without blowing fuse if possible, then one at a time try those circuit loads ie: horn, brake pedal and so on, if you isolate which load is pulling to many amps(blowing fuse) unplug that load itself, then restart testing, see if fuse stays ok. You can also substitue the fuse with a circuit breaker and unplug each load until click(of breaker) stops.
Locating 3 amp fuse to radio which is secondary fuse after main fuse at the fuse block under dash. Followed wiring diagram which indicates fuse should be near or inside radio enclosure.
Question edited for clarity, 'fuse', unless you light it 'fuze'.Question moved to sub category.
If the radio has an inline fuse, it will be within 82 of the plug at the rear. They are built into the harness. Unlikely because there are three fuses covering audio.
https://fuse-box.info/isuzu/isuzu-trooper-1992-2002-fuses-and-relays
C11 10 (AUDIO[ACC]) MIRROR Audio, Door mirror, Door mirror control SW, Door mirror folding SW, Digital clock, Speaker C12 20 CIGARETTE Cigarette lighter C13 10 ANTI THEFT Anti-theft controller C14 15 STOP A/T CONT Stoplight SW (w/o cruise control), Brake SW (w/cruise control), Rear wheel anti-lock brake controller, Stoplight, Transmission control module, Electronic brake control module, Trailer harness connector, Cruise control unit, A/T shift lock control unit, Lockup off relay C15 20 AUDIO[BJ] Horn, Horn relay, Horn SW, Hazard warning light SW, Flasher unit, Anti-theft horn, Hazard warning light, Audio C15 20 TELEPHONE Telephone C16 10 CLOCK[B] ROOM Digital clock, Audio, Dome light, Map light, Luggage room light, Courtesy light, Door SW (Front, rear, tail gate), Antenna, Anti-theft controller, Key remind SW, Seat belt, Key & light remind buzzer
My 1983 Monte Carlos fuse box labels are worn off. I need to know if I got all the fuses I need or if am missing fuses
1. 5 Amp (Tan) - Instrument panel lights and lights-on reminder
2. 20 Amp (Yellow) - Choke heater
3. 30 Amp - Circuit Breaker. Power windows and sunroof
4. 10 Amp (Red) - Electronic control module
5. 25 Amp (White) - Heater and air conditioning
6. 20 Amp (Yellow - Stop and hazard lights
7. 25 Amp (white) - Windshield wipers
8. 10 Amp (Red) - Radio and cruise control
9. 30 Amp - Circuit Breaker. - Power door locks, seats and rear window defogger
10. 20 Amp (Yellow) - Courtesy lights, key warning chime, power antenna, horns, cigar lighter and clock
11. 20 Amp (Yellow) - Turn signals and back-up lamps
12. 20 Amp (Yellow) - Parking, side marker, license plate and tail lamps
13. 10 Amp (Red) - Warning lamps and buzzers, trunk release, torque converter clutch and vehicleicon1.png
speed sensor
2helpful
Words on fuse box diagram faded. whats the appropriate fuses?
Please review this article: Where's The Fuse?
speed sensor
14. Not Used
My daughters 1998 vw cabrio has a top that won't go up or down. i need to find the fuse for it. i know it's not the motor or hydrylics i have already checked those out. so that leaves the button or the...
"my daughters 1998 vw cabrio has a top that won\'t go up or down. i need to find the fuse for it. i know it\'s not the motor or hydrylics i have already checked those out. so that leaves the button or the fuse... but i don\'t have a diagram for the fuse box. Please help. "
Here's the list and link for the fuse locations.
Fuse/Relay Locations on 1996 VW Cabrio.
Fuses, left to right:
1. Head light, low beam, left
2. Head light, low beam, right
3. Instrument & License plate lights
4. Glove box light
5. Wiper/washer
6. Fresh air fan
7. Tail light & side marker, right
8. Tail light & side marker, left
9. Rear window defogger
10. Fog lights
11. High beam & indicator, left
12. High beam, right
13. Horn
14. Backup lights
15. Open
16. Dash warning lights
17. Emergency flasher & turn signals
18. Fuel pump
19. Radiator fan & AC
20. Brake lights & cruise control
21. Interior lights & digital clock
22. Radio & cigarette lighter
Relays
1. AC
2. Rear window wiper
3. Digilant control unit
4. Load Reduction
5. Open
6. Emergency flasher
7. Fog lights
8. Intermittent wiper
9. Seat belt warning
10. Open
11. Horn
12. Fuel pump
13. Radiator cooling fan
14. Starting interlock
15. Open
16. Open
17. Open
18. Daytime running lights
19. Auto trans
20. Open
21. AC & power seats
22. Power windows
Google Image Result for http://www.2carpros.com/forum/automotive_pictures/266999_cab_1.jpg
1helpful
Not able to find the fuse in my 2007 Volkswagen Jetta for the cigarette lighter can you tell me which one of these is it?
well here is mine but is 2003 and i dont think they have changed to much ...
Fuse identities for A4.....
-----------------[ S8 ][S 12][S 16][S 20]
-----------[ S5 ][ S9 ][S 13][S 17][S 21]
[ S1 ][ S3 ][ S6 ][S 10][S 14][S 18][S 22]
[ S2 ][ S4 ][ S7 ][S 11][S 15][S 19][S 23]
[ S 24 ] [ S 31 ] [ S 38 ] -- -- --
[ S 25 ] [ S 32 ] [ S 39 ] R R R
[ S 26 ] [ S 33 ] [ S 40 ] S S S
[ S 27 ] [ S 34 ] [ S 41 ] -- -- --
[ S 28 ] [ S 35 ] [ S 42 ] R R
[ S 29 ] [ S 36 ] [ S 43 ] S S
[ S 30 ] [ S 37 ] [ S 44 ] -- --
S1=10 AMP=Heated washer nozzles, glove compartment light, memory seat...
S2=10 AMP=Turn Signal System
S3=5 AMP=Fog Light Relay, Instrument Panel Dimmer Switch
S4=5 AMP=License Plate Lamps
S5=7.5 AMP=Comfort System, Cruise Control, Climatronic, A/C, Heated Seat Control Modules, Day/Night Dimming Mirror, Control Module and Control Unit for Multifunction Steering Wheel.
S6=5 AMP=Central Locking System
S7=10 AMP=Back-up Lights, Speedometer Vehicle Speed Sensor.
S8=OPEN
S9=5 AMP=Anti-Lock Brakes.
S10=10 AMP for GAS/5 AMPS for Diesel=ECM
S11=5 AMP=Instrument Cluster
S12=7.5 AMP=B+ (battery positive for data-link connector) (DLC).
S13=10 AMP=Brake Lights
S14=10 AMP=Interior Lights, Central Locking System
S15=5 AMP=Instrument Cluster, Automatic Transmission Control Module (TCM).
S16=10 AMP=A/C Clutch, After Run Coolant Pump.
S17=Open
S18=10 AMP=High Beam Right
S19=10 AMP=High Beam Left
S20=15 AMP=Low Beam Right
S21=15 AMP=Low Beam Left
S22=5 AMP=Parking and Side Marker Lights, Right
S23=5 AMP=Parking and Side Marker Lights, Left
S24=20 AMP=Front Wiper Motor, Washer Pump
S25=25 AMP=Fresh Air Blower, Climatronic, A/C
S26=25 AMP=Rear Window Defogger
S27=15 AMP=Rear Wiper Motor
S28=15 AMP=Fuel Pump, Gas Engine Only
S29=15 AMP Gas/10 AMPS Diesel=ECM
S30=20 AMP=Sunroof Control Module
S31=20 AMP=Automatic Transmission Control Module
S32=10 AMP Gas for Fuel Injectors/15 AMP Diesel for ECM
S33=20 AMP=Headlight Washer System
S34=10 AMP=Engine Control Elements
S35=30 AMP=12 VDC Outlet in Trunk
S36=15 AMP=Fog Lights
S37=10 AMP=Radio Terminal 86S, Instrument Cluster
S38=15 AMP=Central Locking System (w/ Power Windows), Luggage Compartment Light, Remote Fuel Tank Door, Rear Lid Unlock.
S39=15 AMP=Emergency Flashers
S40=20 AMP=Dual Tone Horn
S41=15 AMP=Cigarette Lighter
S42=25 AMP=Radio System
S43=10 AMP=Engine Control Elements
S44=15 AMP=Heated Seats
1helpful
We had the distribute replaced and now the brake
Sounds like a fuse, in the underhood fuse box, the brake lights & cruise are on the same 20 amp fuse. After replacing the fuse, check the brake lights first. Then see if the horn works, horns usually are the cause for a blown fuse, they short out.
1helpful
Electrical problem after battery replacement.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
1helpful
Main fuses for the horn and air bag
Fuse #8, #18 and #22.
8 - 10 Amp - Airbag
10helpful
3answers
Jetta electrical problems
hi, i recently bought a used 2001 jetta and had the same problem...auto locks, sunroof, windows, interior lights, trunk switch on door all stopped working all of a sudden. replaced fuse #14 and everything works like magic again...
I found this fuse diagram A LIFE SAVER!!!
S8=OPEN
S17=Open
hope this helps ; )
Top Acura Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Acura Expert? Answer questions, earn points and help others
