Question about Casio Exilim EX-FH20 Digital Camera
Hi.. just ask how much ex-f1? - Casio Exilim EX-FH20 Digital Camera
Posted by cutedog08 on
damneddle
    President:
  • 1,607 Answers
It costs around $530 - $675
Posted on May 17, 2011
How can I make the focus ring work on my casio exilim ex f1?
The manual (pg 43) says that each time you press the FOCUS button, it will advance between Auto (AF), Macro (Flower), Infinity (Sideways 8) and Manual (MF). You can use the < or > keys to focus , or the ring if set up as described below:
Next, the focus ring can be programmed (pg 85) by pressing [REC] -> [MENU] -> [REC Tab] -> [Ring Setup]. Choose "CS fps" for Continuous Shutter Speed (pg 46), "Zoom" (pg 40), "Focus" (pg 43), or "Off" for no function at all.
You can download your manual here.
I f this was helpful, please rate it 4 thumbs up. Thanks!
Sep 22, 2011 | Casio Exilim Pro EX-F1 Digital Camera
(Fn) key function
Fn or Function key is used for your F1 up to F12 keys. Ex. Fn+F5 is to turn on the wireless capability. Fn key is like a shortcut for the functionality of the machine. You can also adjust brightness by pressing Fn+Up or Down arrow and for the Volume Fn+Left and Right arrow.
Apr 29, 2011 | Lenovo IdeaPad Z360 Notebook
As i turned on the monitor the screen shows CMOS WRONG PRESS F1 TO SETUP PRESS F2 TO LAOD DEFAULT VALUE
hi,
first of all check the main battery back of ur machine by unplugging from the mains power supply. if machine shuts off, then u have to replace the battery.and then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
if the main back up battery is ok, then another possibility is the CMOS backup battery of ur machine have some problem. that's why it loosed all the seted parameters. then u have to replace the CMOS battery of ur machine. normally 3V battery. then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
ok
Jan 13, 2011 | Dmm UT4000F Multi-Parameter Patient...
Computer randomly recognizes Casio Ex F1 through USB
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Nov 24, 2010 | Casio Exilim Pro EX-F1 Digital Camera
The monitor screen will not come on the Casio Exilim EX-S770 digital camera. Can it be fixed???
Yes. It might be the back light or inverter. If we're lucky, it could be just a loose connection - it has to be disassembled.
Nov 23, 2010 | Casio Exilim Pro EX-F1 Digital Camera
Spanish manual Casio Exilim Pro EX F1
You can download the Spanish manual for Casio Exilim Pro EX F1 by clicking this link:
http://www.support.casio-europe.com/es/download/manuals/dc/EXF1_110_s.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Jan 30, 2010 | Cameras
The pictures on the f keys..Im pushing them but nothing is happening..for example..f1 is home key..not going to home page when I push it
The function keys that have the pictures on them have dual functions. You need to press and hold down the Fn key and then press the Function key with the symbly/picture to get the 2nd function/option.
Eg. For the Home key press Fn plus F1 key.
Jan 04, 2010 | Logitech Cordless EX 100 Mouse
Where is the wireless switch on easynote r4622
Hi Young Mik431, the switch you are asking about is the (f1) key in order to activate the wireless you must press the Fn key and then the f1 key you have now turned on the wireless
Dec 11, 2009 | Packard Bell iMedia SL 9553 (P660401806)...
Need usb cable to casio exilim camera EX-S10 what type of USB connector is on this camera, not mini A or B. thx
i f i remember correctly, this camera has input/output terminals. both for USB/AV port and a USB: high speed USB.
http://cgi.ebay.com/Casio-USB-cable-Exilim-EX-S10-S5-EX-F1-EX-Z100-150-200_W0QQitemZ120460169326QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item1c0bfc506e&_trksid=p3286.c0.m14
http://cgi.ebay.com/Casio-USB-cable-Exilim-EX-S10-S5-EX-F1-EX-Z100-150-200_W0QQitemZ110426500160QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item19b5eeac40&_trksid=p3286.c0.m14
Aug 31, 2009 | Casio Cameras
Nyko Airflow EX race simulation games such as the F1
Have you tried something like ascociating the turning of the car to the mouse in game then ascociating the mouse to an analouge?
Feb 18, 2009 | Nyko Airflow EX PC Game Controller...
Casio Exilim EX-FH20 Digital Camera Logo
46 people viewed this question
Top Casio Cameras Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Casio Camera Expert? Answer questions, earn points and help others
