Question about UTStarcom Cell Phones
I accidentally turned my phone's main lcd lights on "always off" and I can't seem to turn back on the screen. I need help on trying to turn back on the screen, it's not broken or anything, i just accidentally turned it off. UTSTARCOM PHONE MODEL # CDM 9200 thank you.
Posted by timothyyang on
terry gardiner
  • 34 Answers
Try taking your battery sim and memory cards out wait a few minutes and replace turn off the phone first, you might also try your provider and they will run through the sequence , if you have your manual you should be able to go through it blind, hope this helps good luck,regards terry
Posted on May 17, 2011
Crack inside screen blue red green lines
You have cracked your LCD screen (the screen that displays the picture). The glass on top of it is called a Digitizer Screen (the screen that recognizes your finger). This is a fixable problem, but the cost to repair will depend on the phone, insurance or lack of, and who you get to repair it for you....hope this helps you some.
Nov 28, 2012 | Cell Phones
LG led tv turns on okay but no picture sound is okay
you're gonna need to take it in for a diagnoses. There is an internal fault going on. There could be several things that can cause your problem. I'd guess you have a problem with either the main board, or T-con board. I'd lean more toward the main. But again get it diagnosed !!!
Sep 07, 2012 | LG 47LE5400 47 in. TV
Can't seem to fully turn off the tv? It always stays on stand by? Please help
thats just the way they are, i have a 32 inch samsung flat screen and you just have to turn it off from the plug, i guess its a safety thing to make sure you do switch it off by the mains. they used to tell you that in the 70's after the last programme finished at midnight, ''and don't forget to turn off the tv and switch it off by the mains'' i just hope its easy to reach for you
Nov 02, 2011 | Bush Industries IDLCD26TV16HD LCD TV
I have a Sony DSLR A-300 and the lcd screen on the back of the camera goes white when I take pictures. How to fix this?
The camera has live-view, so is the LCD always white? Can you play back old pictures or view menus properly? Do your pictures turn out white or are they ok?
If it's always white and you can't see anything, you need the LCD replaced or the cable going from the main PCB to the LCD replaced. 99% likely the LCD, not the cable.
If you can playback old pictures and view menus... but NEW pictures turn out white then it's not a problem with the LCD screen at all, it's the CMOS or something else.
Without knowing more detail it's hard to say exactly what's wrong, but it definitely sounds like the camera needs repair.
Thomas
Jul 24, 2011 | Sony Alpha DSLR-A300 Digital Camera
Pleas how to repair my nokia 3110c light problem
hi,
there are several reasons why there is no light in your lcd screen.
1) you accidentally turn off its lcd backights if your unit has that features. check on it on display settings of your phone.
2) probably your phone experience accidental impact and that causes lcd flex connector to get loose and causes no light for the display.
3) busted lcd backlight or open line connection to backlights.
I recommend not to open your phone since it is very tricky to open it and there's a great chance of damaging the LCD and also your unit is still in warranty and if the warranty sticker is broken, your warranty is void. instead have it repaired to your phone dealer or provider and that saves you from trouble.
but if you really to gamble and give it a try (Don't do this if your not sure what your doing!), you can fix it yourself if the problem is on no. 2 (loose connector). open your phone slowly (since delicate parts inside and remember its part placements) using t6 or t7 screws and locate the lcd flex connector (usually behind the LCD) that connects the lcd to the main board. remove it slowly not to damage it and look for abnormalities, if none, then put it back securely and assemble your unit. then give it a try...
Good Luck!
Don't forget to rate me OK! Thanks...
Hope i helped you...
bst rgrds,
John
Jan 06, 2011 | Cell Phones
There is problem in my sony ericsson hazel that is in warranty period and no light in there in screen and all functions r running is this is physical damage or not ?
hi,
Good Luck!
bst rgrds,
John
Jan 05, 2011 | Sony Ericsson Cell Phones
Round lcd?
Unfortinetly i cant recommend to you a quick fix or a quick check as the fault seems to be intermittent,
i would suggest taking the player to your cdj pioneer dealer.
email: [email protected] for all your dj equipment repairs.
Thanks.
Aug 16, 2008 | Pioneer CDJ-800 Turntable
My sony ericsson light on the main screen stop working
yes it could be the LCD is damaged or you may have to replaced the main-board
Jun 16, 2008 | Sony Ericsson W850i Cellular Phone
Cell Phones Logo
94 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tafi Nami
Tafi Nami
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
