Question about Sony (CDR320E) CD-RW/DVD-ROM (Combo) Burner
Do not read any dvd or cd ......... - Sony (CDR320E) CD-RW/DVD-ROM (Combo) Burner
Posted by suresh sah on
Brian Sullivan
  • Sony Master
  • 27,725 Answers
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 17, 2011
tip
What is the difference between DVDRW and DVD-RW?
Simply <br /><br />cd rom = read cd 700m only <br /><br />cd rw =read cd 700m and write on it <br /><br />dvd rom =read cd 700m and dvd 4.7g only <br /><br />dvd rw= read cd 700m and dvd 4.7 gb and write on it <br /><br />dvd compo= read cd 700m and write on it and read only dvd 4.7 not write <br /><br /><br />best regardes
on Apr 02, 2011 • Computers & Internet
tip
What is the differance between cd devices types
Simply .........<br /> <br /> cd rom = read cd 700m only <br /><br />cd rw =read cd 700m and write on it <br /><br />dvd rom =read cd 700m and dvd 4.7g only <br /><br />dvd rw= read cd 700m and dvd 4.7 gb and write on it <br /><br />dvd compo= read cd 700m and write on it and read only dvd 4.7 not write <br /><br /><br />best regardes my friends
on Mar 31, 2011 • Computers & Internet
My acer aspire3680 laptop dvd writer cannot read dvd. they read only cd's.i have Dvd Decoder but still cannot read dvd's. why? plz send me answer my email address- [email protected] .com
I have also the problem of yours but i have the solution and i do it with my pc now it read DVD/CD
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Dvd rome is not write the cd or dvd
you have dvd rom
it can only for read cd and dvd
dvd combo
it can only read cd
write cd
read dvd
dvd writer
it can read/write cd and dvd
When I put a cd r in my burner then press burn selection then it
Try downloading a program called " RadarSync" it works like driver detective, might possibly help you out.
www.radarsync.com/
Pioneer DVR-109 DVD±RW...
This ahs to with speed of recording of the CD/DVD try reading CD/DVD burnt at a lower speed like 16x.
Most DVD writers has low maximum reading speed as compared to CD-ROMs.
You can try burning a CD on it and then reading it, if reads then it shows that other cd were burnt at faster speed than it can read.
If it read lower speed CDs then you can just add an additional DVD/CD-ROM just to read faster speed disks.
1helpful
5answers
Combo drive not reading DVD
my combo drive also not reading dvd :(
4helpful
4answers
Dvd writer doesn't read or burn dvd/ but only read CD-R plz reply to [email protected]
have you installed the softwares to burn DV/CDs? maybe you hadn't installed the softwares yet. normally samsung uses NERO. check the installation kits.
Sony (CDR320E) CD-RW/DVD-ROM (Combo) Burner Logo
Top Sony Computers & Internet Experts
Ekse
Mehandi Husain ...
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
