Question about Leviton 8599 GFCI Receptacle
When I turn on my flouressent light on my gfi kicks out. not a problem with any other things. skill saw, table saw, etc
Anonymous
There's a short or ground fault somewhere in the switch, wire or light fixture.
Process of elimination can locate problem.
Replace the switch, and check circuit.
Disconnect wires from florescent and connect trouble-light pigtail, and check circuit.
Replace light fixture.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 17, 2011
All the outlets and lights in the garage quit working. We know the fuse in the box is working and cannot find a GFI on the circuit. We tested the wires and they appear to be hot. Any ideas?
All newer construction will have a gfci on circuits run outside (including garages) find the gfci it may be under the house. If it's a breaker it needs to be switched off fully then switched on, sometimes breakers have popped but don't show visible signs
Good luck
Most saws have breakers some also have online fuses check it out
May 01, 2017 | Saws
Saw just quit.Reset didn`t work,are there fuses?
Are you plugged into a GFI? If so you may need to set the GFI receptacle also plug it into a different plug in and see if that works. In saying that I bought the same one and burnt out the motor in less than one hour from purchase. with not cutting any more than five pieces of pine board. They did replace the saw for me.
Apr 12, 2015 | Craftsman 10" Radial Arm Saw Table...
Why would our Model 702-27, be kicking the breaker. Tried changing plugs, but as soon as the breaker is reset and then the machine is turned on it kicks. The machine is full of product, and was runn
What breaker? The GFI on the wall plug?
If so,liquid may have entered the device and tripped the gfi breaker at the wall plug OR the main panel that provides power to that wall plug.
Nov 10, 2014 | Taylor 702-27 Tabletop Soft Ice Cream...
Pump kicks GFI breaker. If I can't get it fixed I would like to find a suitable replacement of a different make.
test Gfi with any other three prong device that you can carry out there an test it with (drop light, vac cleaner,ETC.) , if gfi holds on! replace pump
Oct 24, 2014 | Little Giant Garden
Ryobi 10 inch table saw trips breaker when he turns onRyobi 10 inch table saw trips breaker when you can it on
First of all the saw needs to be plugged in directly to a outlet . NO Extension CORD !!! If it is Right , then Check on the motor label and see how many AMPS the motor is ? You need to then check the Breaker box and make sure the breaker is big enough to handle the load of the motor on the saw . You may have to make sure that the saw is the only thing on that breaker . NO Refrigerator , A/C , ECT.
Also make sure that the motor is clean and not packed full of saw dust . This can over heat the motor and kick off circuit breaker fast .
Good Luck , Hope This Helps !!!!!!!!!!!!!!
Aug 22, 2014 | Saws
Quit running when I turn the switch on nothing
1- You likely overheated the motor find the small red button on the end of the motor and push it after the motor cools down some
2- You tripped a circuit breaker in the electric panel, go to the panel and look for the breaker that does not line up with the rest of them and move it off then back on.
3- If your outlet has a GFI on it go reset the GFI reset button.
Nov 07, 2013 | Delta Saws
Saw worked fine until today. Kicks breaker withing seconds of starting. both 15 and 20 gfci's kicking within seconds.
What I would check for and follow closely, is UNPLUG tool turn blade by hand to make sure it turns freely, there could be a piece of offcut wood jamming the blade. then turn it on its back or however you can to see about cleaning with compressed air, check the cord condition for breaks if all the above checks out and sounds like you have tried different power sources you have an electrical short and troubleshooting this is involved.
Oct 03, 2010 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
On my fathers c10fl table saw the thermal breaker constantly trips, even under light loads. The saw is only 3 years old and has rarely been used. I have it plugged in directly to a 110/120 volt, 20 amp...
As a Contractor I always bypassed the on board breaker switch cause i found them to be a pain and always trippin. If you are concerned about burning up the motor i would just install an inline breaker like a GFI outlet. Please give a 4 thumbs up if you have found this free answer helpful. Good Luck and have a Great Day.
Apr 02, 2010 | Hitachi C10FL 10" Stationary Table Saw...
Have an old Black and Decker 7321 Skill Saw. Bought it used. Cant figure out how to change the blade. Help
With the saw UNPLUGGED, check around the base of the motor shaft, there should be some kind of button that you can depress to lock the blade from turning. Then with the appropriate sized wrench, turn the blade locking bolt clockwise (it is a backward thread) to loosen it. Then simply remove the washers, etc carefully and replace them the same way they came off. If there is no locking button, you can use a scrap piece of wood on the saw table and push down on the blade to lock it in place.
Aug 08, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
I have a skill table saw model 3400 type 2. The
I would check to see that ID of the blade arbor matches the OD of the motor arbor, and you are not missing an adapter ring. Then I would get some acetone and a wire brush clean all surfaces where the blade seats. This is also good practice for Jacobs chucks on drills, that allow the drill bits to spin.
Jim
Aug 04, 2009 | Skil 10" Table Saw 3400
Leviton 8599 GFCI Receptacle Logo
73 people viewed this question
Top Leviton Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
john h
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
