Check behind the tray any paper stuck back there? Try swapping the paper from portrait to landscape or vise versa.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Canon iR5000 Tray 3 problem
look behind the tray and see if there is paper stuck behind the tray. Good luck
SOURCE: Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
SOURCE: EP3050 error code C0040
A C0040 error code indicates a problem with the suction deck fan. It has nothing to do with the paper lift motors.
The fan is accessed by removing the rear cover of the copier. It is right in the center. These are readily available (p/n 9313-1310-61) although they are not cheap (around $200 retail).
SOURCE: an error code occur ed
C0500 is a fuser warm up failure code. The procedure to reset is simple. First look at the right side edge of your control panel. This is where the meter count is and the "slide" that controls how dark/bright your display screen is. Now just to the left or front side of where the slide is you will see a small hole in the panel. You need a small paper clip or a tooth pick to insert into the hole. Next with the machine turned on and showing the code, insert something into the hole until the screen goes blank and begins to restart. You should see something that resembles the copier sitting on top of the globe. Keep watching the screen and at the far left side of the screen there will appear a small dot. As soon as the dot appears press the 3 key. You should now see a screen with several boxes. At the lower left is "Trouble Reset" - Press this box to reset the code. Do this reset procedure ONLY 1 time for every 10 minutes. If the code comes back you can try again in 10 miutes. If the fuser is heating and the machine just can not "see" it then you can do further damage to the machine if you try to reset several times very quickly. If the machine warms up and makes copies you are all set. If the code comes back you have a failure in the fusing unit and will need it repaired.
This procedure works on the Di250 Di250F Di251 Di251F Di350 Di350F Di351 Di351F.
Please provide positive feedback if I was helpful.
Good Luck and Thank You for using Fixya.
This error message means that the printer has determined that the length of the paper in the source specified on the second line of the display is too short to print the formatted data. For auto-size sensing trays, this error occurs if the guides are not in the correct position.
Please try to do the following
? Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
? Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
? Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
For further assistance, please contact Lexmark Technical Support.
• Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
• Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
• Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
