Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042 Logo
Question about Husqvarna Riding Lawn Mower 42 Inch Cut Yth2042
I have a Husqvarna 42"
Kelly
  • 3,740 Answers
You should have the Oil & filter changed per this manual:
http://www.managemylife.com/mmh/owner_manuals/10223/CRAFTSMAN-Lawn-Tractor-L0304249?
To make sure you have the correct manual go to this link and enter your model number:
I tried this model number and it did not work: 960.50002 I think you are close though.
Make sure that it is warm if you can before changing oil. One Procedure calls for removing the transaxle to change oil... It takes 80 oz of 20-50W oil. It is important to FLUSH the transaxle if you are experiencing problems. There is a product caled engine Flush that you can purchase to flush the transaxle.
Mose transaxles that experience motion problems are caused by contaminated oil. Flush.. flush... flush.., then wait for it to drain out... and then finally re-service with 20-50W oil.
Change the Filter too.. if your unit has one. All of them have the internal metal mesh screen which is why it is so important to flush out the debris.
Thanks for choosing FixYa,
Kelly
Posted on May 26, 2011
Adjustment on the hytrostatic transmission
the transmission could need repair, oil may be bypassing in side the trans,if you have fixed apuncture lately, check to see if the key is sill on the axle
1helpful
I can't seem to turn off the full bag alarm on my
sounds like the switch is stuck, find the switch and lubricate. Tim
2helpful
When first start my husqvarna yth 150 runs fine goes up hills plenty of power after running for while starts loosing power wont go up hills will stll move on flat surface
Hi, it sounds like the hydrostatic drive is getting too hot. Remove the battery and battery cradle and clean all grass and debris from around the hydrostatic drive and cooling fins. Also check the fan wheel on the hydro is not damaged. Regards Phil.
Top Husqvarna Garden Experts
Dwain Pippen
Jay Finke
Jay Finke
Marvin
Marvin
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
