Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
This is a common problem of Model: 34788,
34788-I, 34988, AC34788, GE48800 etc.
You need to replace air purge solenoid (Air purge solenoid located on
top of the ISV tank, if you open front panel cover then you can see it on top
of the tank).
After doing above stapes and your
problem still exist then you have to replace PCB relay board. Just claim for warranty
(Air purge solenoid and PCB relay board) from where you bought the machine.
Hope
this will help to solve your problem, if so please vote for it for farther help!
Good luck
Posted on May 17, 2011
There are other items to replace before a PCB board and that is not the way to warranty items
Posted on Jul 17, 2012
Aug 18, 2011 | Measuring Tools & Sensors
Jun 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
Jun 02, 2011 | 2003 Ford Focus
This is a common problem of Robinair 34700Z / 347002K &
347112K series machine. So don't worry just do the following, with POWER SWITCH
OFF: - 1# Open front panel cover and verify the ISV tank is not overfilled. If full,
carefully remove refrigerant manually from ISV tank by pressing tank valve. 2# verify
if there is high pressure in the ISV tank. Purge excess air from the tank
manually. (Open air purge hose from the ISV tank, then carefully press tank
valve as needed to blow out excess pressure from the ISV tank)
After doing all above stapes and your problem still exist then
replace air purge solenoid (Air purge solenoid located near the ISV tank and
fixed with automatic air purge device). Hope this will solve your problem, if
so please vote for it for farther help! Good luck
May 17, 2011 | Robinair Cool Tech 34700Z Recovery,...
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
Jan 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
Jul 12, 2010 | Robinair Cool Tech 34700Z Recovery,...
Jul 12, 2009 | Heating & Cooling
May 04, 2009 | 1999 Buick Park Avenue
Oct 07, 2015 | Robinair Cool Tech 34700Z Recovery,...
2,669 people viewed this question
