Unfortunately, you did not provide any specifics. Please Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
Ok so the DK code means that the Black drum counter has reached its limit
# , * , c , *
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
L1-00 means that the scanner unit under the glass was interupted in it travle and didnt return to home position within a specified time. Often you can restart the power to clear this.
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green
lever and pulling the toner out. Open the left side door. look at where
you just pulled out the toner and there is one screw (facing you)
holding each drum in place - loosen the screw and pull the drum unit out
towards you....slide in the new drum unit. to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
DK means the black drum has reached its maintenance life - 50k copies. you need to buy an ARC26DU drum unit. The drum counter will need to be reset after its installed. here is a starting point : http://electronics.pricegrabber.com/fax-copier-supplies/Sharp-ARC26DU-Developer-Toner-Drum-Cartridges/m12754437.html Hope that helps.
I see this is an Office all in one.
Fax works you say - sending also via the scanner?
or sometihng else go into more detail of the operations of this device.
