Hi Jack,
First I want to appologize to you for not getting back to you right away. I was not actually online at the time that you purchaced my services. I had simply forgotten to log out. So I am just now getting the message that you have asked for my help.
Anyway, if your other windows are working, this eliminates several possibilities. Your passenger window circuits can all be tested from the passenger window switch connector without having to take a lot of stuff apart. I have uploaded the wiring diagram for your window circuits. You can download a FREE copy at the following link:
Window Circuit-01.gif Just scroll down to the bottom of the page and select the link that says "slower download" , wait for the timer and enter the "captcha code" to download the file. Please note that you
DO NOT have to purchase a "filesonic membership" to download the file. I have had problems with people thinking that I am trying to "sell" them a filesonic membership - this is simply NOT TRUE. The only thing I am selling is MY SERVICES and this is just one of the methods I use to deliver them.
When you check the circuits at the PASSENGER window switch, this is what you should find if the circuits are all working properly:
The BROWN/WHITE wire (pin 3) and the VIOLET/WHITE wire (pin 2) should both be GROUND with the driver's switch in the NEUTRAL position. The wire at pin 3 will switch to battery power when the driver's switch is in the UP position and the wire at pin 2 will switch to battery power when the driver's switch is in the DOWN position. If these conditions are not what you find, then the problem is either the driver's control switch or the wiring between the driver's switch and the passenger switch.
The BROWN wire (pin 8) and the VIOLET wire (pin 5) work similarly, however they are both grounded when BOTH switches are in the NEUTRAL position. These should toggle between power and grond when EITHER switch is operated. If the circuits above (pins 2 and 3) are working like they should, but these wires are not, then the problem is the PASSENGER switch. If ALL of these circuits are working as described, then the problem is the window lift motor.
Please study the wiring diagram so you can understand how this is all supposed to work.
If you need any further assistance, please respond back to this message to let me know.
Thank You for your patronage,
Dave (dttech)
