Question about Scubapro Service Diagrams Scuba Regulator 1999-2002
My regulator makes a high pitch noise while breathing.
Posted by cafferyj on
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
High pitch noise when on or off
Some ferrite cores of power supply regulator might poise this problem. Check for it.
Jul 07, 2012 | Samsung P2370HD 23 in. TV
High pitched noise when the T.V. is off. The noise only occurs when the T.V. is off and the red light is on.
Such symptoms caused by damage or problems from the POWER regulator, comes from the transformer noise. usually caused by too high output voltage over 125 Volts. and is caused by other parts in the power regulator has been damaged or weakened, for example. is elco on the part of regulators. like to elco 100uf/50Volt size, 220/50 Volt. you can replace it, here Otocoupler in the regulator.
Aug 31, 2010 | Proscan Televison & Video
Barbeque is making a loud high-pitch noise. Can't
The diaphragm inside the regulator is vibrating; that is what is making the noise you are hearing. You could go out and buy a new regulator, but first I want you to try something. What I want you to do the next time you light the grill is to not open the tank valve all the way...only open it about 1 1/2 turns and light the grill. If the noise goes away (which, most likely, it will) then the easiest way to correct it is just to not open the valve all the way. Normally, all one needs to do is open the valve halfway and the grill will get plenty enough gas to give you a really hot cooking area.
Or, you can go get a new regulator.
Dec 13, 2009 | Grilling
The heater fan on my 98 chevy silverado stopped working... worked on high at first but made a high pitched noise and stopped all together
Run 12V directly to the motor and see if it will run, if it dosent than the motor is bad, if it does than the resister is bad, the resister makes the blower run and also regulates the speeds for the blower, but chanses are if it was making a high pitch squeel before it quit the motor went out.
Dec 10, 2009 | 1999 Chevrolet Silverado 1500
High Pitched Humning Noise
It is the regulator trying to vent off with a restriction. As long as it is working it will be ok to use but I imagine its days are numbered.
Jun 29, 2008 | Kenmore 16322
High pitch noise in 27PT6441.
Check regulator and large filters in PS. Capacitors.
Sep 21, 2007 | Philips 27PT6441 27" TV
Scubapro Service Diagrams Scuba Regulator 1999-2002 Logo
199 people viewed this question
Top Scubapro Scuba Diving & Snorkeling Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Scubapro Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
