Since there is nothing you can do to fix this at home you have 2 choices, replace the camera or send it back to the manufacturer for exchange (very expensive)
follow following steps. I followed all these and its working now :) 1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment. 2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc. 3. Try turning the camera with the lens facing down and shake to dislodge anything stuck 4. Try removing batteries and memory card, wait 5 minutes and refit the battery only. 5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec. i hope it will gives you success. ThanksSwapnil
Hi there please follow the steps and let me know the result.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try. Pay particular attention inspecting around the gaps of the circumference of the lens barrel for any sand particles. A single grain stuck in those narrow gaps can jam the barrel.
Hi there its happens when the lens not ready for work. Some how its not able tostable his focus method. That's why its stuck. There is a chances of lens guide pin disturbed or damaged & thats why continues buzzing. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Focus is stuck - could be sand or something in the focus gears. That's the weak spot for these lens. Contact your local Olympus service center or any other camera service center or me at [email protected]
Hi! Hi!
The focus is stuck. Could be sand, dirt or something in the focus gears - well known problem for these lens. Contact your local Olympus service center, but
if they ask too much, you can contact me at [email protected]
and I will give you a good price.
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
