Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
I want to know how to make copies of DVDs and audio CDs using acer aspire 5742 laptop
Posted by vanessa576 on
  • Anonymous Jun 30, 2020
    DVD burning rules. (not CD nobody uses those now)
    Simple steps. and rules, and simple failure causes.
    Rule#1 the source disk must not be copy protected as you buy them off the movie shelf at walfart.
    1:the DVD drive tray front must be marked (or top sticker labled) DVD R/RW) or will never burn any DVD-r or DVD+R
    2:The drive must read DVDs known to be good and CDs too.,
    if not the driver is bad or the drive is bad or the DVD media disk is bad.(even scratched)
    3:Get IMGburn.exe free and safe run this APP. 100% safe, used my me 1000s of times.
    4:click copy DVD to image file (hdd must have space, 5GB or more)
    if Fail, the DVD source disk is bad or the actual DVD drive is bad.
    5: Click copy Imageg to DVD-R. if fail the disk is not blank or the drive is bad.
    of serious, check the box,verify in IMGburn.exe.
    common cause of failures is upgrading to windows 10 and W10 does not support your old DVD drive.
    Ask MS for help on that.
    or ask your OEM PC maker for help there, most will say sorry w10 does not run on 2005 PC.
    if the DVD drive is 15 years old why expect it to work or even have W10 support.?
    good luck burning,
    if asking for help tell the helper 2 things
    what PC, what OS a
    what is on that DVD source disk (vast things possible) but movies to the list.
    example.
    DVD has 25 MS Excel spread sheets on it. for whatever.
    DVD has 500 MP3 files on it (music,etc)
    DVD has real off the shelf (OTC) DVD movie on it, fail you will.
    DVD has 1 home movie on it as MP4 file, (easy job this)
    end.
Chris Hingee
  • Acer Master
  • 32,281 Answers
You need programs to copy DVDs and CDs. This WEB site has a free program that copies CDs and DVDs.
http://www.thefreecountry.com/utilities/dvdcdburning.shtml
Posted on May 16, 2011
Roman
    Sergeant:
  • 158 Answers
Download and install Nero Burning Rom program, open it, set in the up window the option CD/DVD, get to preferite, copy CD or copy DVD option, depends by what you need, set the speed 4x for DVD or 8x for CD for have a good copy quality, insert the original disk, it will copy it, then insert the new disk to burn.
Need manual for aspire5742-6439
Got here as quick as I could.............just a minute, I'm out of breath!
Whew!
Acer Aspire 5742-6439 product review,
http://techwiki.hardwarecanucks.com/product/2MTExNTc4NQ/Acer-Aspire-AS5742-6439-Notebook/#pics
For specifications in case you need them.
Acer Aspire 5742 series disassembly guide,
http://www.laptopguides.info/acer/acer-aspire-5742-service-manual/
On this page go down to the bottom of the paragraph, and left-click right on - Acer Aspire 5742 Service Manual.
It works, I'm looking at the Service Manual right now.
Aspire 5742/5742G/5247Z/5742ZG Series Service Guide
[ The above is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name ( Acer Aspire 5743 Service Manual), it may take up to 30 seconds, before the first page comes up ]
Not what you had in mind?
User Guide,
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=3277
Now, may I ask what the problem is? Post back in a Comment.
Regards,
joecoolvette
May 13, 2012 | Computers & Internet
My wireless has disappeared on my laptop acer/aspire
You can try Fn+F3 to bring up the launch manager, by which you can turn on your wireless.
Let me know if that doesn't work.
Dec 05, 2011 | Acer Aspire 5742 Notebook
Is the 'DVD-Super Multi DL Drive' on the Acer 5742 Aspire basically a DVD rewriter, or does it just play DVD's?
This Super-Multi Drive will write to dual layer DVDs (DVD+R DL or DVD-R DL) at a 4x speed. The full specs of the Acer 5742 are available here: http://support.acer.com/acerpanam/notebook/2010/Acer/Aspire/Aspire5742/Aspire5742sp2.shtml .
You should be able to place a dual layer dvd in the drive and have it recognized. Windows may ask you if you want to format the disc.
I hope this helps.
Oct 08, 2011 | Acer Aspire 5742Z-4200 Notebook
My default erecovery in not working plz help Acer aspire 5742
Have u created a recovery disc when u set up the computer for the first time. If yes, u can try that. Or else u can get a copy of that disc by calling the Acer Tech Support. Also you can try installing any other OS of your choice if your hardware is compatible.
May 18, 2011 | Acer Aspire 5742 Notebook
Why won't my CDs or DVDs fit into the DVD drive of my Acer Aspire 5742-7438 laptop? The piece of plastic in the centre of the drive doesn't fit through the hole in the CDs or DVDs.
A super simple answer would be to take them out of the square case but I think it may be more difficult than that. Most cd/dvd drives have small ball bearings that work like detents and hold the disk in place to keep it from coming off. you have to press down firmly (10-18 inch/lbs of force) to get the disk to stay.
Good luck
Feb 22, 2011 | Computers & Internet
My acer aspire 6920 is not runing dvd's, but it works with normal CDs. All normal CDs work, just the freaking DVDs are not working =/ the computer dont wants to open them, but he knows they are in, becouse...
All acer laptop user have same problem i think incluiding me. U must have some bad noise when you use DVD. just try to allinment proper of your laptop position. and wait for a white it will run.. if done thumbs me.
Jan 30, 2010 | Acer Aspire 6920 Notebook PC
I have purchased a tsst ts-t633a external dvd +-RW drive to link with an acer aspire a0531 netbook. The drive will read and write CDs but not recognise DVDs. Can anyone help?
You need a software made for DVDs which you can use for the CDs to.
To read DVDs (and CDs) use Power DVD.
To burn DVDs (and CDs) use Nero DVD. You may purchase them almost to any PC shop.
This is just an example. You may find some free software on the Internet but if you are not used with this I suggest to ask a friend to help you or to buy a software as I have already said.
Oct 06, 2009 | Acer Aspire One PC Notebook
My DVD drive in ACER Aspire 4720 not reading burnt DVDs and CDs
well look for cds that are thicker and sturdier. some low cost CDRs are too thin and/or soft that they cant handle the heat generated by the cd drive.
Jun 04, 2009 | Acer Aspire 4720 Notebook
Cd dvd dont play correctly
speed control in the unit. The DVD can't sync with the audio. It is usually a hardware problem. Need to replace the DVD drive.
Apr 26, 2009 | Acer Aspire 3610 Notebook
Compaq DVD Player problem
You need a new DVD codec. If you have a copy of WinDVD, give it an install. Otherwise, try the free codec on www.divx.com.
Dec 06, 2007 | Acer Aspire 3000 Notebook
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
160 people viewed this question
Ekse
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
