Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
My plantronic 220 explorer blue tooth will not pair with my LG 240 phone, need help
Posted by designerscor on
CARLOS R SOUZA JR
    President:
  • 1,118 Answers
Try to put it in pairing mode, prior to pairing it with your phone. To do it, begin with it turned off. Then, if it is the first time it is being paired, just by turning it on (i.e. by pressing and holding the call button for some 2 seconds), it should enter the pairing mode. Otherwise, keep holding the call button past the time required to turn it on (for some 8 seconds), until its indicator light is flashing in red and blue, thus indicating it is in pairing mode. Either way within the next 2 minutes, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode.
By the way, if its user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards, Carlos
Posted on May 16, 2011
How do i pair plantronics explorer 240 with LG CX265T
In the link below of the user guide for the Plantronics Explorer 240 (230) you'll find pairing instructions on pages 3-5. Also, remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Dec 09, 2011 | Plantronics Explorer 240 Bluetooth Headset
Need to pair my nokia5310 to plantronics explorer 210
You don't mention if this is your first time pairing the headset, you will need to turn on your blue tooth on your cell phone, the light on the headset should come on flashing red/blue. If it does not refer to sub pairing instructions below. The cell phone should find the headset. 2XX Plantronics in your list. If the pass key is needed it is (four zeros). Second time pairing or more than one device, turn on bluetooth feature, headset turned on, press and hold the call button for about 5-6 seconds. Release button and set headset aside. On cell phone hit bluetooth menu, search for add device. The cell phone should find the headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 17, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to link my blue tooth
Pairing the Plantronics Explorer 220:
For most phones, select Settings/Tools, Connections, Bluetooth, On. See your phone's user guide for more information.
With the 220 headset powered off, turn on the headset by pressing and holding the call control button for approximately 5 seconds until the LED flashes red & blue. The Explorer 220 headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again and hold for 5-6 seconds until you see the red & blue flash.
From your phone, go to the Bluetooth menu and select "Search" or "Add Device". Your phone should find the headset which will appear as "2xxPlantronics" in your list of devices.
If prompted for the Passkey (PIN code), enter 0000. If your phone asks for a PIN/passkey, enter 0000 (4 zeros). Pairing is successful when the LED on your headset flashes blue. Your headset is now connected and ready to use.
Here is the link below for step by step instructions.
http://www.headsetsdirect.com/plantronics-explorer-220-bluetooth-pairing-instructions
Good luck from Headset Direct - 800-914-7996.
Aug 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a droid x and a friend gave me an plantronics explorer 240 cause she had gotten another one. I thanked her not thinking to ask how it worked like what buttons was what and how to connect it to my...
First of all, go into Settings and then Wireless & Network settings on your Droid X, then push Turn on Bluetooth. The check mark in the box should be green once its on. Then click Bluetooth Settings. Meanwhile, turn on your headset by sliding the power switch towards the microphone. The light should flash blue and red. Now go back to your phone and push Scan for Devices, at which point you should see something like "XXXPlantronicsHeadsetXXX". Push that, and it should work. IF it asks you for a passcode, its 0000. Here's the Plantronics help site: http://www.plantronics.com/us/common/easytopair/#/explorer-240
Feb 21, 2011 | Plantronics Explorer 240 Bluetooth Headset
Trying to pair my plantronics 220 to my phone and dont have a passcode for it
Most bluetooth headsets use a universal "0000" (four numerical zero's) for the passcode. This device should be no exception from this universal rule.
Hope this helped you?
Jan 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Pairing LG Shne cu720 to Plantronics Explorer 220
Try holding down the button on head set untill the phone reconizes
Jan 01, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics 220
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Aug 14, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
523 people viewed this question
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
Ekse
 Grubhead
Grubhead
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
