Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Maybe you don't have your wireless turned on. Look on
both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle
the wireless on or off. Normally you would Press and Hold the FN function
key located at the lower left of the keyboard, then hit the correct F1 thru F12
key that toggles the wireless. The correct F1 thru F12 key to hit will
have the wireless signal icon )))) on it. Or it might have the icon of a tower
with the wireless signal icon )))). Normally the screen will display
Wireless On or Wireless Off when you toggle the wireless.
