What ???
You have a very strange system. By default, the only assigned attribute to the Users folder is R and the individual user folders have no default assigned attributes.
attrib -s -h changes the attributes to not be a system folder and not hidden, but this is immediately followed by attrib +s which makes the folder a system folder. But neither Users or the user's folder is suppose to be a system folder.
https://support.microsoft.com/en-ca/help/313222/how-do-i-restore-security-settings-to-a-known-working-state
SOURCE: Problem with 'seeing' edited pictures and folders when edited in Digital Image
There is a problem with file association naming! Its pretty simple if you know what you are doing! In order for your other programs to see these files you need to right click on the file and use "open with" and select the program you would like to use. That sometime fixes the problem but what you need to look for is what it says after your file name example(name.tif, name.pdf, name.jpeg)and make sure that the new computer and its software is even compatiable with the old software. Try looking for an update at the software manufactures web site. The always have a support section for customers to keep there devices/software working properly.
SOURCE: recover my documents folder windows xp password
Yess it is NEBULAEHO2!
Put hdd in another pc and make it as Secondary Master ( Remove jumper if it is DESKTOP PC )
Wati 2 min until windows will recognising it! Then copy and paste document!
SOURCE: problem syncing mp3's to mp3 player with Windows Media Player
This isn't necessarily a solution, but:
Within WMP, I believe under Help, Check for Updates. Won't hurt.
Depending on your media player ... you say generic, but there's surely a brand ... you may find it "mounted," like a CD or hard disk, within your My Computer section. On my dad's Sansa, for example, you can directly copy over music files, but videos have to be converted in a certain way. There's a default structure -- that is, there's a folder for podcasts, a folder for music, a folder for movies, whatever.
Without knowing the specifics of your device, it's tough to give a good answer. Try checking for updates, and if that doesn't do anything, then see if you can get at the drive deliberately and start copying over your files yourself.
SOURCE: Missing user names and groups from "Security settings" window
You have to backup all SYSTEM files and reinstall the OS. That's the ultimate solution to your problem.
SOURCE: Folders take too long to open
It might be too early to tell if by just cleaning the registry solved that issue you had earlier but cleaning the registry in general helps in better performance and fix error messages. Having no info about what its really fixing your best bet is to monitor it for a while and make notes when it does happen again.If it does happen again to run the registry cleaner and see if solves it again. It could also have been a missing or invalid references associated with the folder that the registry was able to clean up.
