Go to this link and you might see how to stop it from beeping.. microwave keeps on beeping after use it Google Search
SOURCE: microwave
F3 occurs if the controller detects a key shorted for more than 60 seconds. Luckily, on this model, the "keypanel" as it's called is available as a separate part. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering the model number here: http://tinyurl.com/gv383 The "keypanel" is shown as reference number 44 on that exploded view.
SOURCE: Unkown Beeping During Calls
It is hard to tell if this conference phone is installed on a PBX or not? "At meetings" tends to make me believe that it is. Beeping can come from a few sources. If a call is being recorded it is necessary to provide a beep tone so that the parties on the line know that they are being recorded. This is a FCC requirement. You can ask the other party if they are recording the call. Beeping can come from call waiting. It is recommended to turn call waiting off unless you are bridging incoming calls. If a call is on hold you will get a beeping tone. You can check by pressing the flash button and see if there is a second call. If so hangup and your original call should return normally.
SOURCE: ge spacemaker xl1800 microwave
F3 on a GE microwave indicates a defective keypad.
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
If none or only some of the pads are working, there may be some foreign substance on the circuit board, the keypad connection, or inside the layers of the keypad, the latter of which cannot be repaired.
Trouble is sometimes due to spray cleaner being sprayed directly onto the keypad. Cleaner should be sprayed on the cloth first, then use the cloth to wipe the keypad clean.
Never use an ammonia-based cleaner on plastic as the ammonia can attack and crack it.
A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out, but often that does not work.
Another thing is to unlpug the power at the mains for several seconds. Plug it back in and see if it works. A reset may do it.
At power-up, the display should flash or show a text message. If not, a key may be stuck due to a foreign substance or a defective keypad.
If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board.
To check that, see our critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with a pencil eraser or alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: beeping sound
On GE's that's usually a shorted keypad. We can replace that for you for about $115 total.
We have full details of our service, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide
with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
