SOURCE: PIONEER KEH-P1010
depends on the kind of car, if there is a "CAN" around it then there is a metal cahe that you need to slide 2-4 removal tools in the sides to remove it, you can use any think metal tabs abought 3-4 in long as removal tools,
if its an ISO DIN mount there are screws holding it in from the sides.
if this doesnt help much can you tell me the make and model of the car?
SOURCE: Remove Pioneer radio from dash
Try ebay:
Item number:
370036329272
If the facia comes off, remove it and you should see two vertical slots. Insert the keys and pull out the unit. Disconnect the plugs for speakers power and ariel.
SOURCE: setting clock
Setting the time
This is used to set the time on the unit’s clock
display.
1 Press AUDIO to select the time.
Press AUDIO until the time appears in the display.
2 Select the portion of the time display you
wish to set with 2/3.
Pressing 2/3 will select a portion of the clock
display:
HOUR—MINUTE
As you select portions of the clock display the
portion selected will blink.
3 Select the correct time with 5/∞.
Pressing 5 will increase the selected hour or
minute. Pressing ∞ will decrease the selected
hour or minute.
SOURCE: Please give me the instruction HOW to ADJUST TIME
Go here...
http://pioneerelectronics.com/PUSA/Products/CarAudioVideo/Accessories/AV-Components/KEH-P6010?tab=D
click the DOCUMENTS tab,
and there you will find the original owners manual ,in which the time change instructions are.
SOURCE: I have a car stereo model pioneer KEH-1550
Go to a car stereo place and buy an "install kit" That will solve all your problems. Wiring, and how to fit it in
