Question about Skagen 358SSSD Wristwatch
The crystal of my wife's skagen watch popped out and the nylon ring surrounding the crystal seems too big to get back in, or perhaps I just don't have the right tools. Help!
Posted by hammerheads on
Conrad Jacoby
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 172 Answers
Watch crystals are pressure fitted to their cases so that they are resistant to popping out. Think of a champagne cork, and how it expands when it comes out of its bottle.
Crystals are set into cases in one of several basic methods. First, a crystal may be installed from the back--watch cases are commonly assembled before the movement is installed. So, one potential way of reinstalling your crystal is to remove the watch movement from the case (if it isn't already) and try pushing the crystal from the back forwards. If this is indeed the way it was installed, the crystal should pop into position with a noticeable click or light thump to let you know that the other edge of the crystal has found the shallow groove in which it's supposed to sit.
Second, some crystals can be installed from the front using a tool called a "crystal lift." This tool has many little fingers that compress the edge of the watch crystal so that it can be slid into the case. Pressure is then gradually removed from the crystal, permitting it to expand into the shallow groove into which it's supposed to sit. Crystal lifts are easy to use in theory but somewhat finicky in real life; the crystal must be grabbed equally by all the lift prongs or else the crystal will have a tendency to squirt out of the tool before it's been completely set.
Looking at pictures of your wife's watch, it doesn't look to me like a crystal lift would do any good. I think instead that your crystal might have been installed using a third method. Looking at the pictures, it looks like the bezel--the metal top of the watch--separates from the watch body. If this is the case, gently pop off the bezel and push the crystal into it from behind. Then, push the bezel back onto the watch movement. It's possible that the crystal is kept in place by being squeezed between the bezel and the rest of the watch case.
If all of this sounds daunting, putting the crystal back in--assuming it's not cracked--is a minor job for a watch repair technician. It literally might only take 5-10 minutes to complete the job. If you're concerned about the appearance of the watch, it might be safest to pay someone the small amount of money to get this done right. Replacing a watch crystal with a new one usually runs about $15-25, around where I live. Replacing an undamaged crystal that's popped out should cost appreciably less, since a new crystal costs a jeweler between $5-25 for most standard sizes (diver's watches and strange specialty shapes will cost more).
Posted on May 16, 2011
WHERE DO I GO TO REPLACE A CRYSTAL FACE ON A SKAGEN WATCH
If the watch is under warranty it would cost you $32.00 to have it fixed.
you can follow this link for more information: http://www.skagen.com/webapp/wcs/stores/servlet/ContentView?storeId=37082&page=customerCare_warrantyRepairs&nav=leftNav_CustomerCare&langId=-1&catalogId=26505
The other option is to go to a professional watch repair person to replace or buff out the crystal if it's just scratched. The fees are around $25 - $50 since that watch has a mineral crystal. I hope this helps!
Feb 14, 2013 | Skagen 589SSSB Ladies Steel Black Mesh...
Hi, My wife skagen watch crystal was broken when I took it to a battery replacement place. I have search on skagen to purchase only the crystal without having to send the watch to the US. Is there any...
I have had to replace more glasses in this watch than any other brand over the last two years - It is most definitely a design flaw. The truth is though that you will not need a genuine skagen part. Your local watch repair shop will be able to use a standard 1mm thick domed Mineral Glass manufactured by Sternkreuz for example. It should be fitted by a qualified watch repairer, but you should not need to send it to Skagen. Good luck
Sep 20, 2010 | Skagen 358SSSD Wristwatch
My battery wend dead. the store will not open the back of the watch to change it. how do i open the back to change the battery?
Thank you for contacting FixYa.
Most Skagen watches have a snap-in, snap-out back. You will need a case back opening tool ($3 to $14) or a slotted jeweler's screw driver or knife blade to pry it open. Do this over a counter or towel in case the battery pops out. Examine and make note of which side of the battery is up. Get the number off the battery, better yet take it with you to Wal-Mart, Radio Shack or anywere else they sell batteries. Buy a replacement, install it, and try to reinstall the back. Good luck!
Do not try placing your Skagen watch face down on a soft towel, on a hard surface, and then then try to mussle in the back, or tap it with a mall or hammer. You very likely will break the crystal.
Without a Case Closing Plier ($15 to $20) or a Case Closing Press ($15 to $50) you will not be able to get the back to snap back in. You could try a conventional vise and size some vinyl or plastic washer to to fit the bezel and protect the crystal/face of the watch, and some flat vinyl/plastic that covers the back of the watch. Align the front and back plastic pieces with the back, carefully insert it in your vice, and tighten until the back snaps in. This could be fatal if you mess up!
A simpler solution is to take your watch to a place that specializes in selling and servicing a variety of watches, hopefull Skagens, maybe a jewelry store, and have them replace the battery. They should have the closing tool and you can expect to pay $10 to $15 for the battery and installation.
If you like Skagens, you can go on-line and find the appropriate tools to do this. Or, pay the watch store. Many Skagens use up batteries at the rate of every 10 to 15 months. Also, you can look up Skagen on line and see if they will service your watch. They are located in Reno, Nevada
Aug 28, 2010 | Skagen 358XSSLPD Wrist Watch
How Much it cost to replace a skagen watch glass.
$34 will cover it when you send it to skagen they will fix the crystal and check everything else for that much while still not voiding your lifetime warranty.
http://www.skagen.com/service/orderWatchBandParts.fx
May 21, 2010 | Skagen 170LTTM Wrist Watch
Broken glass and new strap
Hi Chris,
Skagen watches have very thin domed crystals and they do break. Because of how thin they are it doesn't take a lot of pressure to break the crystal.
Crystals are not something any watch company covers in their warranty.
The crystal can be replaced. Either Skagen can replace them or a qualified watchmaker can. Prices vary and it would depend on how much you are willing to spend as to if it was worth it to you.
Apr 14, 2010 | Skagen Men's - MEN'S MULTIFUNCTION...
I require a new crystal for my Skagen 240SSX watch. Any suggestions?
skagen.com will replace your crystal for a very low price. other than that you may find it hard to find a jeweler that'd do a good job.
Dec 10, 2009 | Skagen 240SSX Wrist Watch
Hi, One of the hands has fallen off my Skagen watch; the crystal will have to be removed to re-attach it. Who can do it, and for how much?
Just about any qualified jewler that sells watches will either be able to do the work or refer you to someone that can. The crystal shouldnt have to be removed. The case back comes off and then a retainer ring of plastic or metal comes off. The crown is removed and the movement should come out. I wouldnt suggest you try it yourself as jewlers use special tools and jigs to attach hands. Cost shouldnt be too bad depending on the jewler.
Jul 22, 2009 | Watches
Watch battery and manual for Skagen 271sgxd
try sending it to skagen they can fix your watch and you will still be covered under there lifetime warranty!
http://www.skagen.com/service/watchWarranty.fx
p.s. the manuals are all on this site as well!! thanks!
Jul 03, 2009 | Skagen Ladies - DEMI CRYSTALS LINK WATCH...
The crystal on my Skagen titanium developed a pressure crack which, in less than a day, spread to almost a complete circle. Crystal obviously must be replaced. Who does this work and how much does...
Contact the manufacture to find out who their authorized service rep is for your area.
I had the glass or crystal break on some of my watches. The glass or any outside parts are not normaly covered by warranty.
Jerry G.
Sep 15, 2008 | Skagen Watches
I've replaced the battery on my Skagen watch but am having trouble snapping the back on -- any ideas would be greatly appreaciated. Thanks
O.K this is a tough one, because a watch maker has a press to do this. I don't know if your watch has a round crystal or if the crystal is domed. If it is round and flat, lay the watch down with the crystal side face down. Lay it on a flat scratch-proof item. Take a wooden handle that has a domed end to it. Take the back and lay it on the watch case, making sure that the knotch on the back is aliegned with the setting crown. Take the wooden tool and using the domed end put a little pressure on the endge watch case near the edge, and slowley go around the back, it should snap into place. If it's a domed or square crystal, that's a little harder and all I can think of is finding a round concaved something that fits aroung the edge of the casing NOT hitting the crystal ,and do the same thing as with the flat crystal ( go around the edge putting a little pressure on the back) For a square crystal
Jul 07, 2008 | Skagen Watches
Skagen 358SSSD Wristwatch Logo
603 people viewed this question
Top Skagen Watches Experts
Janelle Schoonover
Janelle Schoonover
ray gallant
john h
Are you a Skagen Watch Expert? Answer questions, earn points and help others
