Koss KS4110 DVD Player Logo
Question about Koss KS4110 DVD Player
When I try to use my dvd player I put a disc in it says loading them it comes up and says bad disc, it will also do this if there is no disc inserted into it, can you help me? I don't know the model # I tried cleaning the disc also a different disc and nothing happens I don't have a book with it either. The last time I used it it was perfectly fine
Posted by s_chromick on
Anonymous
    Guru:
  • 586 Answers
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Yours sincerely.
Elect_Comp.
Posted on May 15, 2011
Kris Sprouse
    Habit-Forming:
    Scholar:
  • 135 Answers
You can check on this for more solutions and details:
How to fix a DVD "No disc" error (3 solutions)
If you can't solve this, you can also download a free Blu-ray player program which can be an alternative to it, such as Leawo Blu-ray Player
Posted on Jun 02, 2020
My dvd player has just stopped playing disc's? I insert a disc, it loads up as the little circle comes up, saying loading. Then it says bad disc.It stops. Does anyone know what could be wrong here?
Couple things could be. I've found : the disc can be dirty, wipe it off. Or if its damaged the lens won't read it.
What usually helps the most is to put a lens cleaner in the player. they sell them. I only have a CD cleaner ( prob called lens cleaner). It still fixes it for me.
Insert disc.....
May be looking for a firmware update disk. Try looking on the panasonic website for firmware updates for this unit. Burn the file to a disk and put it in the machine and let it load.
Insert dvd but comes back saying no disc inserted
Hello
Your DVD players loading mechanism has some fault with it. It does not load the disc properly in, Check the loading belat first, and the loading motor for low pulling power. Check whether there is any fault loading gear wheels. The fault is clearly of the loading mechanism itself. OK.
I put a DVD in my Digitec DVD player. it says Loading for about 2 minutes and then says no disc with all dvd's but it worked less then 24hours ago
try to open the case of your DVD player, insert the DVD disc and then see if the disc is spinning and loading, otherwise the optical DVD laser lens is weak.. you have to replace it.
2answers
PCH-DVD 300 says every disc I insert is a "Bad Disc"
First thing to do is clean the lens with a good quailty DVD lens cleaner, it that doesn't work you have a fault, in either the lens or the electronics.
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
Any disc put into dvd player shows up as BAD DISC
your DVD player lens needs to be cleaned by a lens cleaner...
3answers
Bad disc
I have the same problem with some of the Discs I have burned. Most people say the power supply, but I have 2 of these units so I swapped the power supply to see if that was it. The problem stayed in the one machine, ruling out the power supply.
Bad disc or insert disc problem
If you are using a copied disc try a real one. But this model of DVD Player is made so cheap. it sound like the laser assembly is bad or the motor that spins the disc is stuck or going out. If you are good at electroninics you could take the lid off load a disc and see if it spins if not give it a spin clockwise and see if it takes off. You probably should replace unit for price of a new one.
Top Koss Televison & Video Experts
Marvin
Marvin
Tom Chichester
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
