Question about Canon PIXMA iP1500 InkJet Photo Printer
After adding black ink to my canon pixma ip1500 it stopped printing and gives me error 5600
Posted by wiggie415 on
Reparatii PC - Service IT
  • 2,574 Answers
Service Call Error :>>No print head detected excepting print head replacement (during printing)
Replace the printer as it has failed.
Posted on May 16, 2011
My Pixma iP1500 will not print in colour even with a brand new ink cartridge and after deep cleaning. Black printing isperfect.
go to controlpanel>printer> ur printer driver..
check the settings..
if u r unknown of the settings restore default if u r printing from ms word see the print options and in advanced there will b the link to print color. check the appropriate one .
there u go. now print as much as u want
Mar 10, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Canon Pixma ip1500, bought new ink, cleaned print heads with alcohol, still not printing
Did you buy factory new Canon cartridges or third party cartridges.
If you are using factory new Canon ink, call Canon about their defective ink.
If you are using anything else, want to bet there is no such thing as a warranty.
Don
Feb 27, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
Canon Pixma ip1500 is printing but very wierdly. random lines will not show up in black. If i change the color everything is fine but black will skip lines and such. Please help! Can't turn in job...
Your printhead is plugged and needs cleaning. If you remove the inks and then the printhead, you can wet and fold a paper towel and just dab the printhead gently on the wet towel. When you see a solid black line on the paper towel your printing should be improved.
Jun 23, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
I have cannon pixma ip1500 printer sold in good working condition buyer wants refund saying the waste absorber is full, therefore dont workHELP
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 15, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
PIXMA IP1500 - CANON PRINTER
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Jan 09, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Canon pixma 6000 trouble
check nozzle then test print , if bad result of color not in bold or having spaces incolor means needs to clean, press head cleaning , test print color good then ok. If still having a problem
replace w/ canon original color ink.
Jan 03, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
PRINTER CANON PIXMA IP1500
your printer maybe long period of time does not use , the head already dry , replace w/ " original canon ink" not a generic.
Dec 28, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
PIXMA IP1500
1.open print preview it is visible the option of printing adjustment /
2. The ink are empty , Reload w / genuine canon ink
Dec 15, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
509 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
