Question about Yahoo Messenger
D3d9 dll error to download yahoo messenger - Yahoo Messenger
Posted by zaidi_aleeza on
Kiddi1000
    New Friend:
D3D9 stands for DirectX version 9 (as far as I know) So i would assume that you do not have DirectX installed.
This should be the link to the correct DirectX 9 Download
http://www.microsoft.com/downloads/en/details.aspx?familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3
Posted on May 15, 2011
When downloading yahoo messenger, why do I get an error that says Yahoo did not finish installing because there is a missing component?it says d3d9.dll was not found
Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the d3d9.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX10 and DirectX9 files but they run side-by-side without problem on all of these operating systems.
Dec 03, 2011 | Yahoo Messenger
Message that d3d9.dll was not found....this is registry error, run reginout cleaner it will fix dll error
Download Directx From here and install it.
http://www.filehippo.com/download_directx/download/90ae8f5bd1652097a51c66a550abc588/
If u have any problem let me know.. thank u
Jun 06, 2011 | Yahoo Messenger
When i am installing yahoo messenger during installation an error comes d3d9.dll not found reinstall it........now what can i do plz help me.........
ANY Yahoo! Messenger program will not install properly if a former program, or an incomplete install, has not been completely deleted from the computer first. (Don't worry - your Contacts List will be saved into the fresh installation of an updated Messenger!)
Delete all Yahoo Messenger references from the registry.
  • Use the Control Panel > Add/Remove Programs method,
  • Then double-check by going to Start > Search > files and folders > Yahoo! Messenger (notice the exclamation mark in the title).
  • Write down and delete all references manually if necessary. The uninstaller works well for Vista and Win 7, but not for XP - it leaves behind MANY junk files when uninstalling.
  • If you are using Internet Explorer 8 or 9 as your browser, Yahoo Messenger 10 will not work properly without Flash and Java programs installed, and possibly the .NET framework update. (Messenger 11 is still in beta format, so be wary of using it yet.). you'll have to download Flash and Java programs as well.
Last, you could used this link to fix a dll error:
http://fix-all-dll-errors.com/d3d9.dll/
Just click on the link, then click the button "Fix dll errors now." This should fix the issue. Hope this helps. Thank you for using FixYa!
May 20, 2011 | Yahoo Messenger
D3d9 file is not working
Download d3d9.dll >>click here to download d3d9.zip and copy the dll file to C:/Windows/System32
-or-
Download and run d3d9.dll fixer tool! ->> http://www.dll-files.com/dffsetup_d3d9.exe
May 17, 2011 | Yahoo Messenger
D3d9 not found
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/d3d9.dll/
as I registered few dll's from this site as it is free...worked in my case :)
Feb 17, 2011 | Yahoo Messenger
I install today the least version of messenger11. after i install i cannot open my yahoo messger... it said cannot d3d9.dl cannot locate... i already retry to install but its the same problem what should...
If you've already downloaded d3d9.dll from one of those DLL download sites, remove it from wherever you put it and continue with these steps.
  1. Restart your computer if you haven't yet.
    The d3d9.dll error might be a fluke and a simple restart could clear it up completely.
  2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the d3d9.dll not found error.
  3. Assuming the latest DirectX version from Microsoft doesn't fix the d3d9.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
    Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
  4. Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with d3d9.dll and a reinstall could do the trick.
  5. Restore the d3d9.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your d3d9.dll error, try extracting the d3d9.dll individually from the DirectX downloadable package.
  6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Applies ToThe d3d9.dll error message could apply to any program that utilizes Microsoft DirectX, most commonly video games. Any of Microsoft's operating systems since Windows 98 may be effected by d3d9.dll and other DirectX issues. This includes Windows 7, Windows Vista, Windows XP, and Windows 2000.
Dec 21, 2010 | Computers & Internet
When i download yahoo messenger 10 then there is an error of d3d9.dll after installation. pleas give me some solutions
Download the Filehippo software update checker and see if your Microsoft Directx needs updating
http://www.filehippo.com/updatechecker/
Aug 20, 2010 | Yahoo Messenger
Everytime I try to download and install yahoo messenger I get an error message saying that I'm missing d3d9.dll.
~ d3d9.dll is a process belonging to the DirectX program . d3d9.dll is DirectX DLL for DirectX9. It adds DirectX functionality for Windows Multimedia tasks and games. ~ Determining whether d3d9.dll is a virus or a legitimate Windows DLL depends on the directory location it executes or runs from. ~ Click to Scan your PC including d3d9.dll to Detect any Security Threat. ~ You can download it separately.
Jul 02, 2010 | Yahoo Messenger
Yahoo Messenger Logo
198 people viewed this question
Top Yahoo Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Barbat Nae
Barbat Nae
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
