Question about RCA CC-439 Camcorder
I have borrowed an old rca vhs camcorder inhopes of converting 4 vhs tapes to dvd. I have a Pinnacle systems DVC 90 to plug from RCA to Computer. I cannot get to cam to open? I charged the battery but when I push Stop/Eject Button thee door does not open-I have never operated one of these- No Manual? Help Bob
Posted by robertlukars on
Anonymous
    New Friend:
  • 26 Answers
It sounds like one of my older, been-in-storage for awhile, camcorders. When they sit for without being used fairly regularly, there is often a bit of dampness that settles into the camera. If left in a warm room, this may help dry it up and allow the open/eject function to work. To help it get un-stuck, you could gently press inward on the door (do not pry outward) and try to loosen it up. It may take a few times with this process to allow the door to jar loose.
Posted on May 16, 2011
How do I connect my panasonic vhs 188 camcorder to a dvd recorder?
On these old models of VHS camcorder, I recall they have either RCA outputs, or BNC connectors which will require a BNC adaptor (to convert to RCA).
Using a 3RCA lead, connect the camcorder to the video (and audio) inputs of your DVD recorder.
Sep 19, 2011 | Panasonic AG-188 Camcorder
I have a Sony Handycam Vision CCD-TRV65 and I want to convert the video to DVD to a VHS, how do I do that?
using the RCA outputs and an RCA patch cord, Input the signal into a VCR line input. Play the video back on the camcorder and using a good, high quality VHS tape insert in VCR and press record
Jan 17, 2011 | Sony Handycam CCD-TRV87 Camcorder
I am connecting my dazzle to my pc and to the back of the x box but i try to use windows movie maker to record footage but i cant seem to find the dazzle capture card anywhere on the pc even though i have...
Welcome to Fixya,
What is the model of your dazzle device? Is taht DVC 100? if ever please check this procedure.
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task. step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
Step 7: The tricky part no one ever mentions: On the XBox 360 video cable, there is a switch that switches from HDTV to TV. You must switch this to TV!
Aug 12, 2010 | Pinnacle Dazzle DVD Recorder
No Picture
Hi And Welcome to Fixyah,
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
May 14, 2010 | Pinnacle Dazzle DVD Recorder
No video from dazzle to pc
Hi and welcome to Fixyah,
I have something that can help you with, please checked if this is the same settings.
If you follow any of the videos, it won’t work!
Let me know what happen.
Apr 09, 2010 | Pinnacle Dazzle DVD Recorder
Conversion vhs to dvd
I can only offer you 1 option for this case.
In converting the VHS video tape to DVD you can use computer. All you need to have is the VHS player with RCA audio video cables. Then a computer that has video capture card or USB capture card. This will take time but you can just transfer all the copyrighted videos to DVD and to computer data (post to internet)
*Needs realtime transfer VHS to Computer with the prefered resolution option.
*Burn to DVD, it will depends on your DVD drive speed.
Mar 26, 2010 | Video Cameras
How do i connect dazzle to tv to record ps3 gameplay
Welcome to Fixyah.
Step 4: Plug the Yellow, Red and White RCA connectors from the PS3 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Regards,
Mar 20, 2010 | Pinnacle Dazzle DVD Recorder
How would i upload live footage from and old camcorder, rca cc4352
They make a usb to rca converter box, that comes with a program. Do a search on camcorder vhs to dvd
Nov 23, 2009 | RCA CC4352 Camcorder
I have a JVC DR MV7SU DVD/Video recorder. How do
If your camcorder allows you to connect to a tv or vcr and allows you to record from it to the camcorder via the rca video input, then you should be able to record it that.  The camcorder must have the RCA audio/video inputs on it to be successful.
enov8
Mar 08, 2009 | JVC Televison & Video
Recording Snow
If you hook your VCR up to the RCA jacks on the front of the DVD recorder, push 002 on the remote to use the front input jacks. (001 if you hook your VCR up to the rear input jacks)
Push record on the DVD recorder, and push Play on the VCR.
(Pg. 35 in the manual)
When you push play on the VCR, you should be able to see the movie being played on your TV. If you cannot, make sure your RCA cables are good and hooked up correctly.
That's all you have to do, so if it's not recording I would try to take the unit back for an exchange.
Dec 03, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Open Questions:
RCA CC-439 Camcorder Logo
Top RCA Video Cameras Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
