Question about Kenwood Excelon KVT-915DVD Car DVD Player
Kenwood KVT-915 + Car Antenna + FM/AM
The other day I noticed that my Toyota 4Runner antenna extends up as soon as I power the Kenwood head unit. It usually only extends upward when operating in AM/FM mode. It never extended in TV/DVD/SIRIUS.
Question: Is there a way to ensure the SUV antenna extends up in AM/FM mode only?
Posted by mr23ryu on
5 Related Answers
Anonymous
  • 111 Answers
SOURCE: about kvt 915
Unfortunately the brain and wires for KVT911DVD aren't compatibles with the KVT915DVD,but you may find them at ebay.com
If you find the brain by it selft you can order the cables from pacparts.com
Posted on Feb 09, 2008
Anonymous
SOURCE: kenwood kvt 911 dvd head unit
I have a question. Everything is working perfectly except for there is no picture on the TV nor DVD. It was working fine until the other day when I messed around with some wires seeing if any of them were loose. Any suggestions?
Posted on Mar 26, 2008
Anonymous
  • 4 Answers
SOURCE: kvt-617 dvd receiver hideaway unit
go to e bay n look 4 someone selling a brain/ hide away unit for cheap..????to use with ya dvd unit.
Posted on Apr 24, 2008
Anonymous
SOURCE: kenwood kvt 717 dvd
Which cables?
Model # KVT 717DVD
FLAT CABLE 22P
FLAT CABLE 50P
FLAT CABLE
FLEX CABLE 50P LOC# FPC1
FLEX CABLE 10P LOC# FPC2
try www.pacparts.com all of this information and more can be found in the model number search function.
Hope this helps.
Posted on Jun 23, 2009
Anonymous
SOURCE: kenwood KVT-910 DVD unlock code
i have the same issue. do u have the remote? i don't and i can't unlock it unless i do. did you get it unlocked yet?? kyle
Posted on Aug 02, 2009
Kvt-915 cant find e break wire?
its the green ire on the back of unit. just ground it and the unit will think the ebrake is always on.
Mar 20, 2011 | Kenwood Excelon KVT-915DVD Car DVD Player
I have a Kenwood KVT-514 CD/DVD player that I just installed, But in getting no sound, The Radio works fine but when i try to you a cd or a dvd there is no audio. I've checked my connections seval times...
it sounds like you are using an amplifier. if so you are probably using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on. the power antenna remote wire turns off when leaving tuner mode.
Feb 17, 2011 | Kenwood KVT-512 Car DVD Player
Does not tune in on AM frequency. Cnnot get any station.
do you have your antenna plugged in? you can get some fm stations with no antenna, but not am.
Feb 08, 2011 | Kenwood (KVT-729DVD) Car Video Player
I need the head unit for a kvt 915. or i got the wiring for it, for sale, wires and brain unit.
Try ebay, some time you can find junk yards that has face plate, or other parts. hope this was helpfull
May 13, 2010 | Kenwood Excelon KVT-915DVD Car DVD Player
Kenwood KVT-512 iphone compatibility
Just ignore the airplane mode prompt and if your wiring is correct everything should work.
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
Power antenna on a 1998 Toyota 4Runner?
if the problem is broken , buy only mastil antenna on toyota dealer, no need to change all antenna
Feb 15, 2009 | 1998 Toyota 4Runner
Amp shuts off when switched from radio to cd
your amps rem wire is hooked to the power antenna wire on your head unit and so when you turn off the radio you would nolonger need an antenna so it powers down and would lower the antenna.Depending on the head unit you should have one output for the power antenna and one for the amp rem......If your head unit doesn't have the rem output you can wire it to the switched wire that powers your head unit but keep in mind the amp will stay on while you have the key in acc or run position even if your head unit is off.
hope this helps!
Jan 16, 2009 | Kenwood KAC-9152D Car Audio Amplifier
KENWOOD EXCELON KVT-915 DVD
I have all the components you need. Someone broke into my vehicle and damaged my head unit. [email protected]
Mar 23, 2008 | Kenwood Excelon KVT-915DVD Car DVD Player
Kenwood DDX6019 No Sound with CD/DVD
It is what Turbo911 stated. If you switch the solid blue wire (powere antenna) with the blue&white wire (power control) this will solve the issue. The blue wire is made to power an antenna in which is only used when on FM source. When this is connected to amps, it will shut off your amp as soon as you leave FM radio
Mar 24, 2007 | Kenwood DDX-6019 Car DVD Player
Kenwood Excelon KVT-915DVD Car DVD Player Logo
83 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
