Why I hate iriver music player to the computer but the computer does not recognize
, how can I install the driver for the computer, though it is down a lot of software but may not receive. please give me details of the order to install the driver for the iriver N10 music player ver 1.20
Sure, connect to your computer via proprietary USB cable that comes with the device. Your computer should automatically recognize the new Spinn device. Software is also included in order to manage music, video, & ebooks (text files). Install Iriver Plus 3. Perform media search on your computer. Select files you want to put on your Spinn. Then transfer to your device. Make sure eject your device for safe removal. Thats it.
First make sure you have the right drivers installed, you're hearing the "new device connected" sound when you plug it in, it's listed as recognized under device manager, and the only problem seems to be that iriver music manager isn't recognizing it.
If everything is working except for the music manager, then try holding down the "fast-forward" button at the same time that you connect the cable to the iriver. You probably want to keep iriver music manager loaded, to see if it's recognizing the player while you test this; try attaching/detaching the device several times, while you're holding down fast-forward and while you aren't, to see if that's enough to fix your problem.
I have no idea why it works when it does, it's an ugly kludge, but it seemed to fix the problem for me, and saved me from having to buy an entirely new flash mp3 player to replace this ancient one.
Try plugging in usb with the H10 turned off. Now, press the select button (with the round symbol on it) while turning the H10 on. This starts the player in 'emergency mode' and should be recognized by XP
Make sure you have the latest version of Windows Media Player. XP has all the right drivers but the iRiver needs to synchronise with Media Player inorder to transfer music onto the player using the sync function. Get Media Player 10 or higher then plug the iRiver into the computer.
You could also do the "emergency connection" trick. First, plug the USB into your computer, hold down the "o" button and push the reset button with something that has a point. The computer will recognize your h10 as a hard drive. The you can sync music to your player or just drag-n-drop it. you'll probably need to use a program like "Easy H10" to update your player's database. It's easy to use and it only takes a couple of minutes to update.
