In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end screws into the cold water supply and the hot and cold washer pipes screw into the double end. The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Testimonial: "many thanks, plain english easy to understand "
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
