Question about Kodak EasyShare C360 Digital Camera
Is the memory card of 8 gb is supported by the kodak easy share c360 camera?
Posted by hdtrivedi90 on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
No. You cannot use a 8GB SDHC card in the C360. The C360 supports MMC and SD cards up to 2GB in size.
Posted on May 15, 2011
What size memory card does the kodak easyshare cx6200 take?
The internal memory for this camera is 8 MB.
The manual indicates using memory cards of size 8 to 128 MB, so this is an early SD memory camera, following the original SD standard. Do not try SDHC or SDXC cards. The camera will support a 1 GB card. It *might* support a 2 or 4 GB card, but since this is a 2 Mpixel camera, a 512 MB or 1 GB card will allow you to save thousands of jpeg format pictures.
Mar 01, 2011 | Kodak EasyShare CX6200 Digital Camera
I have a Easy Share Kodak C360 digital camera and I m trying to format a new memory card 4GB and it wont format can you tell me why?
hello marybell769,
I dont know if a digital camera has the ability to format,but if you try to format it in computer,be sure to save all files within it..
Dec 28, 2010 | Kodak Cameras
Just purchased new Toshiba SDHC 8 GB memory card to use in Kodak Easy Share C743 digital camera. Put disk in camera prompt says "Memory Card requires formatting"...press continue, and go to formatting and...
No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
Sep 01, 2010 | Kodak EasyShare V550 Digital Camera
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted...
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
Kodac easy share c330 says memory card full, but it is a new card
Which size has the memory card? More than 1GB?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 03, 2009 | Kodak EasyShare C330 Digital Camera
SD HD card won't format
This camera only works with standard SD cards with a max of 2 GB
Mar 31, 2009 | Kodak EasyShare Z612 Digital Camera
New memory card and the camera says its full
try doing a format with the camera. check your manual to see how to do this with your camera. Beware, formatting will erase anything on the card. i actually had the same problem with my camera, and this worked for me. Sometimes new flash cards are not compatible off the shelf--they need to be formatted. You should have at least flash cards to be sure card is not defective. Let me know if this helps!
Dec 02, 2008 | Kodak EasyShare C330 Digital Camera
What is the upper limit of SD card as GB without any freezing or slowrunning problem in Kodak easy share V1003?
I have a 2 GB SD card that i use on mine, and i dont seem to have any problems with the camera being slow. I hope this helps and good luck!
Jul 13, 2008 | Kodak EasyShare V1003 Digital Camera
"Memory card is unusable"
This error message means that the memory card is slow, corrupted, or unreadable. Turn off the camera then insert a new memory card.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Kodak EasyShare C360 Digital Camera Logo
94 people viewed this question
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
