Question about Kenneth Cole Watches
Installing band on Kenneth Cole kc1491 - Kenneth Cole Watches
Posted by howatt_nate on
5 Related Answers
Anonymous
SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
Posted on Nov 21, 2007
Anonymous
SOURCE: watch bands f/ Kenneth Cole
You can try calling 1-800-874-0907
and here is a link for a KC replacement pdf
http://www.genevawatchgroup.com/pdf/repair_kennethcole.pdf
Posted on Jul 27, 2008
Anonymous
SOURCE: leather watch band
I might have the solution. Is it a rectangular watch with a leather strap? It sounds weird, but I have a watch with no brand name on it (bought yesterday from K-Mart at $9.99) with the model #A126-06. The package insert said "Advance Watch Group." I googled them, and they manufacture watches for Kenneth Cole, Tommy Bahama and a bunch of other designers.
I was really surprised because K-Mart is the last place I'd buy a watch, except that it looked like my broken Raymond Weil tank watch.
I suggest you go to K-Mart and see if you find a watch that looks like yours.
The back of this watch is marked as follows:
V377
Stainless Steel Caseback
2035 Movement
Base Metal
Bezel
20279knx
A126-06
Posted on Aug 10, 2008
Anonymous
  • 109 Answers
SOURCE: HOW DO I TAKE A LINK OUT OF THE WATCH BAND
Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
Posted on Aug 11, 2008
Anonymous
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
Need a link for band
  • The original bands for that watch are very difficult to come by. But having a spare part or two never hurt either.
  • Hope this helps.
Nov 26, 2011 | Kenneth Cole KC3289 Wrist Watch
Where can I get a new band for my KS4003 Kenneth Cole watch? The clasp won't open and I didn't want to pay $65 just for a new clasp. How much is the band?
Thank you for contacting FixYa,
You can contact Kenneth Cole for a replacement band but I am afraid the band is probably going to be alot more then the $65 for the clasp. I would honestly just replace the clasp unless the band is worn in which case I would do the band.
Sorry.
KC can be reached at 1-800-KEN-COLE
Oct 02, 2010 | Kenneth Cole Watches
Do you have a watch band for kenneth cole 1363? many thanks
mcdevito75 here, Best Bet, look for a small watch repair shop in your area for a replacement strap for your Kenneth Cole watch.
Jul 13, 2010 | Kenneth Cole Watches
Where can I get replace band for this watch.. I have had it replace twice and the strap keeps ripping out of the screws. Where can I get another original KC band?
mcdevito75 here, Best Bet, see a small watch repair shop in your area, for the new band, You could get an orginal Kenneth Cole band on ebay.
Jun 28, 2010 | Kenneth Cole 1315 Dial Strap Watch for...
Kenneth Cole leater strip
mcdevito75 here, Almost any watch repair shop can supply a new band, look for the small watch repair shops to save some money.
Jun 14, 2010 | Kenneth Cole KC1333 Watch for Men
Kenneth cole wach band
Have you tried contacting your nearest store?
You can find out their details at http://www.kennethcole.com/helpdesk/index.jsp.
May 04, 2010 | Kenneth Cole KC2315 watch
Watch bands f/ Kenneth Cole
Replacement watch band (f) can be purchased from amazon, take a look here: Amazon com kenneth cole band Watches Women Clothing Shoes Jewelry Wish you best of luck. Cheers
Jun 22, 2008 | Watches
Kenneth cole watches
Link
Good day,
You might want to try above link for your need of a band replacement.
Kindly refer to above link.
Good Bless
May 09, 2008 | Kenneth Cole RK5044 Reaction Watch
Watches Logo
160 people viewed this question
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
