Question about Danby DWC283BLS Wine Cooler
Looking for the mother board for the DWC283BLS Wine Cooler
Posted by jcastilla on
hq120
    New Friend:
    Problem Solver:
  • 12 Answers
Go at sears go to this address http://www.searspartsdirect.com/partsdirect/index.action?pop=flush
and good luck with the repair
Posted on Jun 03, 2011
Fans stopped working
go to sears parts direct and enter your DWC283BLS you will have the plan and number parts you need
Mar 15, 2014 | Danby DWC283BLS Wine Cooler
F230073 p c card
try there http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000/50031952/00001?blt=06&prst=0&shdMod=DWC283BLS
Dec 16, 2013 | Danby DWC283BLS Wine Cooler
Need parts diagram for dwc283bls-1
http://www.searspartsdirect.com/partsdirect/part-model/Danby-Parts/Wine-beverage-cooler-Parts/Model-DWC283BLS/3055/0169000?pathTaken=&prst=0&shdMod=DWC283BLS
Dec 25, 2012 | Danby DWC283BLS Wine Cooler
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Code E4 on dandy wine cooler mod # dwc283bls
We had that problem in 2007, about 10 months after buying it from Costco. It was under warranty so the tech came and changed both sensors. It's worked fine until Feb 11. Now, the lower section ran so cold it froze some bottles. I am looking for a solution to that problem.
Feb 18, 2011 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS has condensation inside the unit.
wine coolers have no means of draining the condensate inside them,use silica gel(1/2 pint)to keep the inside dry(remember to dry it out when condensate happens again)
Jul 16, 2010 | Danby DWC283BLS Wine Cooler
Describe your danby dwc283bls top fan does not work. after removing the fan ,the problem is no output from the logic board, defective board or another part,sensor etc.????
Hi,from your problem,it seems the problem is from the logic board,you can however use a mulimeter to read the voltage supplied by the board,if it reads a low amount of voltage it means the board need to be serviced and cleaned thoroughly,but if it reads no voltage at all meaning its not supplying no amount of power,it means the logical board is bad and needs to be replaced.
Thanks and take care
May 06, 2010 | Danby DWC283BLS Wine Cooler
E4 message
Disconnect the power cord from the wall outlet and wait 30 minutes before pluging back in. This should clear all settings on the cooler.
http://www.danby.ca/cms/uploads/products/en_manual/DWC283BLS.pdf
Aug 07, 2009 | Danby DWC283BLS Wine Cooler
Fan not working
Does it have a compressor and does it run? If so there is probably a relay on that board that is bad or only runs with the compressor.
Dec 16, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
163 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
