How do I properly wire 2 6ohm bose 201v speakers and 1 sub to a yamaha HTR-6130 amp
Posted by mikial meier on
David Dunn
    Brigadier General:
  • 8,546 Answers
According to each product's manual.
Bose.com for the 201's.
Register and download the HTR manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-6130-Receivers-manual/id/15220bh542/t/2/
SUB???
Posted on May 15, 2011
Testimonial: "Thanks for the intel ,i found what i needed "
  • mikial meier May 15, 2011
    Thanks for the Intel I found what I needed
Warning levels
Hello
The (+ve) & (--ve) poles of the connection wires have neen reversed is the meaning. Just interchange the wires of each either at speaker box or at the output terminals of the amp. If these connection are reversed, the sound effect will vary in intesity. OK.
Jan 10, 2012 | Yamaha HTR-6130 Receiver
When my sub is plugged in and i bring up the menu for the sub it displays a -- and no sound is coming of it. what do i do?
Is the sub you are using a powered sub? if not, that's the problem. the sub output is a line level signal.
Here's a link to the manual-see if that helps you.
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/htr/htr-6130_black__u/?mode=model
good luck!
Sep 12, 2011 | Yamaha HTR-6130 Receiver
Htr 5630 shut off in 2 sec.
Sounds like you have a bad amp IC or transistors.
When these go bad they almost always put roughly 40 volts dc from the amp power supply to the speaker terminals. The protection circuit senses this dangerous (to your speakers) dc voltage and disconnects the speaker terminals from the amp via internal relays (the ones you hear click) and puts it into protect mode. If it didn't the dc voltage would quickly toast the voice coils of the connected speaker.
Apr 18, 2010 | Yamaha HTR-6130 Receiver
Bought a Yamaha HTR-6130 doesnt sound good with my Bose. Not enough bass
Have u tried to run the setup / installation, to detect if your speaker system, have or not, subwoofer / size of speakers, etc... or run the manual setup or change the configuration of the bass. -10db + 10db
Jul 26, 2009 | Yamaha HTR-6130 Receiver
HTR-6130 will not turn on
Remove all speakers from the receiver and try powering it up again. If it still shuts down odds are it needs repair of one of the output channels.
Jan 31, 2009 | Yamaha HTR-6130 Receiver
Right rear speaker has no audio
Swap the speaker wire from left rear to right rear if the speaker was from RR now work on LR side this prove the speaker OK then you problem in the receiver
If you swap the RR speaker to LR side and still not work then you
have that RR speaker open
Make sure you hook up speakers cable properly and not short from both terminal speakers and receiver the RED and Black poles
Let me know how you go
Nov 28, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Nov 23, 2008 | Yamaha HTR-6130 Receiver
162 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
