liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
Posted on May 14, 2011
I have a liftmaster keypad and remote and my code all of a sudden won't work.....additional question...i have an apollo gate that the lift master is wired to ... how do i set up the remote to open the gate?
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on May 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
5851
Points
48
My first inclination is that your keypad and remote have been removed from the Logic board memory.
If you have the Opener's instruction manual, then go to the programming section for how to re-program your keypad and remote.
If you do not have your manual then you can go to the Liftmaster website and download / view the manual for your particular unit. You will need the model number for your unit. That can be found near the light fixture on the unit (if you have two light fixtures, then look for a data sticker that indicates Model number and Serial number. You may have to remove or lift the light cover in order to find it.)
This is the link to the Liftmaster website: http://www.liftmaster.com/consumerweb/service/manuals/instructionmanualslanding.htm
To answer your second question, I will need to know what model of gate opener you have, and also need to know if there is a separate Receiver box unit or not. Most Gate operators will have the receiver unit built into them. Some however do not, and an external one will be wired to the gate motor unit, and possibly mounted to a wall near the gate motor. question: do you use the same remote for the gate that you use for the Garage door opener or do you have a separate remote for each? If you do, I need the model number on the remote for the gate operator. That will tell me what kind of tx/rx you have and possibly where to locate the learn button.
Master code on liftmaster TAC1/TAC2
Contact Liftmaster directly to request the master code.
2helpful
2answers
I need a remote keypad for 41a5021-1e lift master. What model will work for this unit
check the liftmaster web-site. also any garage door sites may have parts offerings. google the part number as well.
Lift master 91LM
Won't work doesn't give us much to go on. Does it work with the wall control?
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
I have a lift Master door and the remotes work fine but the door will not open or close using the wall button or the keypad.
Are you sure you aren't stating the facts just the opposite of what they are? That would be a fairly common complaint.
Master lift remotes suddenly won't work. Wired panel button works opening and closing door.
Make sure the light in the wall control is not blinking. If it is press and hold the lock button on the wall control for 3 seconds.
1helpful
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: I need a remote for a Lift Master Professional ...
The model number will be on the opposite end of where you found the part number you listed. You can then call any Liftmaster dealer listed in your yellow pages.
Top liftmaster Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
