Philips 51PP9100D 51 in. Television Logo
Anonymous Posted on May 14, 2011
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
Anonymous
Level 3:
Genius:
  • Master 1,043 Answers
  • Posted on May 14, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1043
Questions
Helped
286025
Points
3188
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
1helpful
2answers
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • tip
    How to set convergence on Projection TV ' s
    I have given an general explanation on most projection TV ' s
    1. Enter the menu on your TV. Use the remote control and bring up the menu.
    2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    4. Press "Enter." A crosshair pattern will appear on your screen.
    5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    8. Repeat these steps for all colors.
    on Mar 18, 2010 • Televison & Video
    It has tripple vision and looks like a bow tie.
  • good luck!
    2answers
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    2helpful
    2answers
    How do you set convergence
    What is your Make and Model number?
    1helpful
    My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
    Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
    1. Press action button to enter MENU.
    2. Navigate to SETUP.
    3. Scroll down to CONVERGE.
    4. Press VOL > to select.
    5. Press CH buttons to navigate up or down.
    6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
    7. Press VOL > to select.
    8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
    9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
      center of cabinet.
    10. Press ACTION button to display red center correction screen.
    11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
    12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
    NINE POINT CONVERGENCE CORRECTION
    Remote Control must be in TV mode.
    1. Press ACTION button to display red correction screen.
    2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
    3. Use the navigation buttons to align the RED cross with the white cross pattern.
    4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
    5. To exit press ACTION button repeatedly, then press CH up.
    7helpful
    3answers
    Can't unlock Samsung Hue?
    samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
    hahah
    1helpful
    Covergence out of alignment on 1/4 Vertical left side of screen
    You need to manually adjust the alignment:
    On remote, press Menu to get to the main menu
    Then arrow down to "ADVANCED FEATURES"
    Then press "enter"
    Then Arrow down to "CONVERGENCE" and press "enter"
    "Red Convergence" should be highlighted
    Press "enter"
    You now have Green, Red, and Blue overlapping crosses.
    If Red is out of whack, use arrows to align
    To toggle to blue (and back to red), press "VIDEO"
    Then align blue cross
    Once the crosses look aligned, and nice and white, press "AUDIO"
    This will bring up the Advanced Convergence screen
    This is a grid of the same overlapping colors
    You have control over the Red and Blue
    If Green is very out of whack, you'll need a repairman…
    While the "target" is flashing, you can move it around the screen with the arrows
    Place it over an intersection to adjust, then press "enter"
    Now the "target" is steady (not flashing), and you can use the arrows move your color
    When it's aligned, press "enter" again
    Now "target is flashing, and you can go to the next square.
    You cannot adjust every intersection.
    Some areas need to be adjusted via the adjacent intersection
    When you're happy with color you're working on,
    Press "video" while target is flashing to change to the other color
    Repeat the above (blue is much harder to see and adjust for me…)
    When you're happy with the entire grid, start hitting "Menu"
    Each press brings you back out one menu level, until you are out of them
    Once you're used to the process, it should take no more than a minute or two.
    1helpful
    Corner convergence for panasonic pt51hx40c projection tv
    Yes there is a Service Code you need in order to set convergence and on this set it is not easy to enter! 1) Switch Antenna to cable (2) Set Sleep Timer to 30 mins,Exit menu Enter ch 124 (3) Now Press vol- on front of TV / A red CHK should appear on screen / NOW enter menu and turn sleep timer off / Exit again,now Press Power untill you see 0V00 press ch up untill you see 0V1 Then Press vol+ you should now have convergence Pattern on screen. To adjust use (ch- ch+ and vol- vol+) (cursor) moves to where you want to adjust (mute) locks place you want to adjust RTune changes R-G-B when done make sure you Save adjustments.
    Convergence settings
    With the remote control,hit the menu key and bring up the menu on screen. Then enter 2358 on the remote for the option menu,enter 2357 for the adjustment menu or 2359 for the convergence adjust menu.
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
