Is the condenser clean and free of dust? If not clean it, that should help. Also make sure the door seals are in good shape and not torn or leaking. If that doesn't cure the issue you will need a new compressor module more than likely. At that point a new Fridge is a real option due to repair cost.
Please, consider getting a users manual, and trouble shooting guide from https://manuall.co.uk/household-appliances/washing-machines/ignis-washing-machines/. The Error code can be decoded. Machine model will be needed. Continuously running pump would an indication the timing mechanism is not advancing. Sensor problem perhaps.
That depends on the manufacturer and in what mode you are operating it. If it's Continuous Mode. Yes, the fan will continue to run, as it's recirculating the air, in an effort to determine if and when the humidity level rises. Then the compressor will turn ON to extract the humidity.
Also, most units will do this if they are running thru the Defrost Cycle. This happens when the cooling coils frost over. It to, is a normal cycle.
So, if you are operating the dehumidifier in Continuous Mode, it's acceptable. \ Hope this helped you. Please let me know. Thanks.
Hellow, If your dryer continues to run when in the off position you nee a new timer dial switch. I hope this helped you out. It would be greatly appreciated if you coud rate my answer. Thanks Mike-
The coil ubder the frig could be filled with dust/dirt and no air is flowing over it to remove the heat. This will causecontinuous running and force the compressor to work harder and louder. A loss of some refrigerant (freon)will cause continuous running but not likely to cause louder running. The fan motor in rear of frig at the compressor could be worn out and running slow or stopped and without this air flow the compressor never stops and runs loud. Also, the door gaskets (especially the bottom part could be torn and bot sealing well; this will cause continuous running but not likely loud running. Goodluck, Macgivor
the fan will continue to run after the power is shut down on a DLP television untill the set has cooled down . But it should shut off within a few minutes
