Question about Lexmark X2670 All-In-One Printer
I just replaced my ink cartiges and now it's flashes E C 5
  • Official Brand Answer
  • 3,344 Answers
The EC5 error indicates a short detected in one of your cartridges. Try to open the printer cover and remove both your cartridges. Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover. If no error, open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the error. You can also try to insert a different known working cartridge to determine if the other is faulty.
Posted on May 31, 2011
    Novelist:
  • 58 Answers
Hello. You can check the error codes that Lexmark printers show on this web page . . . . .
http://support.lexmark.com/index?page=content&id=SO4438&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=&searchid=1275158659149
If your inks are new, just take the cartridge back to the supplier as sometimes a new one can be defective slightly.
Most likely though, the error can be got around by taking the cartridge back out, and finding its copper contacts panel, and very very gently cleaning that with something suitable. Make sure that you DO NOT get any cleaning fluid on the actual print nozzles as this will cause chaos when printing later.
I use foam cleaner, or SERVICOL spray to clean such things when working on them.
I hope that helps.
Posted on May 18, 2011
Tip
How can you clear a cartige ink jam
you can clear a cartige ink problem if it is not printing by rubbing metal part of the cartige by a eraser aur by polishing it by hot water
on Jun 09, 2010 | Office Equipment & Supplies
Tip
How can u use a original cartige for longer period of time
u can use a original cartige for longer period of time by just refilling it before low ink level of the cartige by doing this you can use a cartige for maximum no of time as original cartige is used for once but you can again use that cartige
Hello, I have replaced the ink cartige with an kit refill ink, not with some original cartige. At first it worked, now it shows me that the Black cartige is empy even if if have made the refill. I do not...
all you have to do is to press and hold Resume button for more than 5 seconds, this procedure will by pass the ink level counter and your printer will work with no problem.
Jun 06, 2011 | Canon Office Equipment & Supplies
Cartrige error 1203, what do I do to solve this problem?
It seems your courtige do'nt support in your printer. To continu your printing you need to replace ink cartige. In older cartige you may try the following tecnique:
1. Open your unsupported in cartige.
2. Take a pice of tissue paper and wip smothly both the connector plate and cartige head.
thank you.
Aug 17, 2010 | Lexmark X7170 All-In-One InkJet Printer
EpsomStylusCX3650.
dear sir
it's a cartig problem may be yr cartig is SHORT it means it's circut is damage or not work so yr printer is not recognize that time yr printer understand that there is no cartig avalable so try to replace yr cartig it's help u
Thanks
Please vote
jo_chinmay
Jan 01, 2009 | Office Equipment & Supplies
Dell color cartridges
this sounds wierd to tell you
take out the cartige and if you can take out the cartige holders ( try to reach for the place where the ink flows out) spray it with a glass cleaning solution and let it pass inside where the ink pases and believe it or not it will clean properly the ink passages. try to clean the bottom of the cartige too.
some 1 trid it infront of me and it worked.
ps: an unproper positioning of the cartige will cause the printer not to work.
Nov 09, 2007 | Dell 924 All-in-One InkJet Printer
Lexmark X2670 All-In-One Printer Logo
654 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
