Hi , This is an indication of out-of-regulation in the power supply section. The very
common caused of this fault is the dried-up/leaky electrolytic
capacitor in that section. It
will drop the supply from normal voltage and
will disable the unit and make a clicking relay. Sometimes it has a bulged/dome at the top but not all, it is better
that you have a capacitor
checker/tester to determine
its condition. Also, bad
solder joints can produce the
same symptom, it is hard to spot, you should use table lamp/portable lamp for
finding the cold solder. If you don't have necessary tools
and test instruments, and can't do the job yourself, I would advice you to
look for a professional to troubleshoot the problem. Don't
attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored
electricity enough to hurt you with a little mistake only. Also check if your unit is under warranty /extended warranty,
avail it because the manufacturer of your unit will fix it for free. Don't open
the back panel, this will void the warranty. Hope I helped you. Have a nice day! Thanks for using Fixya.
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
