The blade section pivots to swivel when doing that it allows you access to the blade storage area that holds up to 7 blades, if the extra blades arent in place perfectly the handle won't close properly, if your problem is with the blades themselves, make sure that the slot in the blade is aligned with the holder perfectly
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Good Luck Emily
