Question about Cell Phones
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Posted by twinsoris on
williamkumar
Dear all i am using samsung c5212 my pc windows7 it is not detect my usb connector pls solve my problem
Posted on Nov 22, 2012
Anonymous
    Novelist:
  • 72 Answers
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Posted on May 14, 2011
  • Starla Taylor
    Starla Taylor Jun 01, 2014
    i don't want to connect it to my computer. It stopped charging when I plug my charger into the port. Its not getting a connection
3 Related Answers
satishcool7
Venky iyer
  • 511 Answers
SOURCE: how to connect samsung e251 to pc as a internet modem bluetooth
u need to purchase bluetooth doggle nd install software of bluetooth in pc then connect it ur work is done...
Posted on Sep 02, 2009
Anonymous
SOURCE: Samsung C5212 is not connecting to Samsung PC studio 3
my samsung c5212 is not connecting with pc
Posted on Apr 17, 2010
Gaju9260gmail.comi want how to copy sms from pc to samsung c5212 mobile
Using PC studio If you have activatedinternet on your phone then..first install Samsung PC studio in your PC andthen connect your phone to the PC in wait your PC studio to detect and installdrivers itself...now go to tool box and then to internet connector..select yourdevice and then if it doesn't connects ask setting from your customer care..
After you connect your phone to PC then u can create messages by copying it from PC n save then as saved messages. after that u can access them from phone n then forward ...
Apr 06, 2011 | Samsung C5212 Cell Phone
My mobile is C3212,i have DoCOMO 2G sim,can i use this phone as modem,?
No, this Samsung cannot be used as a modem.
http://www.mobilescat.com/compares/samsung_c3212_duos_vs_samsung_gt-c5212
Mar 12, 2011 | Computers & Internet
I am using samsung C5212 cellphone, I wanted to connet internet of my laptop via bluetooth wireless but I failed, I want to know why?
You should download/install pc studio and then make a connection ("dial up") by connection you phone to the pc.
Mar 08, 2011 | Cell Phones
My samsung mobile is 'GT C3050C'. I install it pc studio, but I cannot use it by modem, I live in Bangladesh, I wanna to know it configuration,
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio.
Nov 21, 2010 | Samsung Modem Configuration Software...
I am using samsung 3g metro gt-s5350 with MTNL sim. I am able to surf the net on the mobile but not able to use it as modem for using internet for my laptop. It is showing "os error, remote device...
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
Procedure
6. Hit OK and exit.
Error 619 solved
2.8 Hit Finish
Nov 08, 2010 | Samsung Cell Phones
Oprea mini for samsung c5212
recently I INSTALLED OPERA 4.3 BROWSER, BUT THE PBOBLEM IS THAT DURING INSTALLATION MESSAGE COMES SAYING '' FAILED TO CONNECT TO THE INTERNET, KINDLY CHECK INTERNET SETTINGS,
RAKESH DESAI PUNE
Aug 09, 2010 | Samsung Computers & Internet
Sir iwant downlod samsung c5212 usb driver wichh site avleble conect mobile to usb leptop internet my leptop pc studio instol but usb driver not fond p/l help
Hey Plz download Samsung Pc Suite over the internet from google than buy a USB cable of the samsung c5212 and get connected to internet
Aug 02, 2010 | Computers & Internet
Im looking for a usb installer of c5212 . my pc cant read the datas of my cellular phone c5212 once i connect the usb cable to my pc
I bought usb data cable PCBS10 for my Samsung C5212, I installed CD but still it shows that mobile not connected.
Jul 04, 2009 | Samsung Cell Phones
Cell Phones Logo
Top Cell Phones Experts
ADMIN Canada
ADMIN Canada
Are you a Cell Phone Expert? Answer questions, earn points and help others
