I have a 27" Panasonic TV. I bought it used and it is more than 5 or 6 years old. Most of times I have no problem with it but some times I feel jumping in the picture mostly in the bottom of window. I see sometimes that 2 or 3 centimeter of bottom of window is removed like a curve. Is it because of the wireless router that is working close to it or this TV has problem? My email is : mojib.sadr AT gmail.com
Posted by mojib on
5 Related Answers
Willie Howell
  • 1030 Answers
SOURCE: 3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Posted on Dec 07, 2007
Anonymous
SOURCE: Panasonic PT47WX49E blue convergence
me too! everything fixed now how do you exit chk mode??
Posted on Feb 20, 2008
Anonymous
SOURCE: Panasonic TV Shuts off by itself
I had the same problem , Good sign of a cold solder or cracked trace.
On my PT51HX41 after a long check with a magnifying glass I found the problem on the main board just below the AC daughter board there is a Blue rectangular box (relay R801) and it had two cracked solder joints.
Posted on Feb 22, 2009
Ecollier2012
Edward
  • 3459 Answers
SOURCE: picture curved in
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on May 22, 2009
Anonymous
SOURCE: panasonic projection tv model # pt56lcz7 no picture, bulb out?
My system is doing the same thing... runs for ten minutes an then no piture and no sound, I just get a blinking green light.
I was thinking heat was the problem, I opened it and vacumed it out. This did nothing.
Now , is it the powersupply or the lamp? Would a bad lamp also cut the sound?
Randall
Posted on Jan 16, 2010
Panasonic TX-P42G10B
5 blinks - check the 5v SOS D Board since the set is a plasma.
Your best best is to obtain a quote from an authorised Panasonic service centre on the likely cost to replace that board if required, then you can make a decision afterwards - to either go ahead with the repair, or cut your losses and purchase a new set if the latter option turns out to be cheaper.
Always ask about and insist on extended warranties whenever you buy a new TV such as plasmas. These will cover you against expensive repairs, and having to buy a new one each time the old one breaks down in the future.
These days manufacturers lean toward board replacement in plasma and LCD TVs rather than individual components, as it is quicker and easier to replace a whole board than to try and fix an old faulty one. It's also tidier in terms of layout.
Nov 18, 2012 | Panasonic Televison & Video
We Have a plasma 42 in panasonic tv that is less than 2 years old. It suddenly popped and now longer works Do you have any advice on how to troubleshoot?
i would contact panasonic and complain that you bought an expensive electric device that should have lasted longer than two years. You might be suprised at how accomodating they can be. Just quote consumer rights to them and dont take no for an answer
Mar 31, 2011 | Televison & Video
Panasonic PT-61LCX65 turned off while I was watching TV. Won't come back on. "Lamp" light blinks once every 5 seconds. Tried turning it on several times per the manual instructions--no change....
Tv projection lamp life are over. Wow 6 years with the original lamp,what u want it last for ever.Replaced the tv projection lamp,will solved the problems.
Feb 25, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I bought a universal remote for my tv vcr combo and the codes that came with it wont work i do not have the original remote what can i do
try these They are the main codes used by panasonic TV's and are from the most upto date book.
Panas on ic 0 0 5 1 ,0 2 5 0 ,0 0 5 5
on the UNIVERSAL select TV1 and SET light comes on and is steady, Enter CODE light goes out press SET
try the on/off if it works thewn it was the right code. If not try the next one using the same sequence.
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Panasonic PV-C2780 27 in. TV/VCR Combo
My 15 yr old panasonic tv turns itself on and off, why?
My thoughts is that after all these years one of the solder joints has cracked and there is enough current that builds up that it will jump accross the crack and work for a short time and then the componenet heats back up and 'well' off it goes.
15 years old. - you got some great use out of this TV.
Maybe time to look to get a new one - These types of TV's were only designed to work for 10 year and then throw them away. Be aware that the new ones are only made to last 3 to 4 years. I know - I don't like it either. They cost a lot more than that Panasonic did when it was new.
Blessings,
A/V Media Guy
Nov 22, 2009 | Proton MM2701VT 27" TV
A month ago our house was struck by lightning and The Insurance company wants to know what the price of the Television. Or what it is worth today. He purcheased the TV about 4or5 years ago. the tv was...
$150 usd- $177usd. SEE HERE
$200 SEE HERE
Quote from the link...
" My Bottom Line
Considering the price, I am pleased as punch with this purchase. Expecting to receive only basic features, the Orion shouldn't disappoint. Audio buffs should look elsewhere, but at a purchase price of approximately $150 for a 27" TV, one isn't looking to the STV2763A as a high tech set. I'm sure I'm forgetting certain specs here, but this my low tech review of a low tech set. I'm happy with the Orion, a nice balance of value and price."
Amount Paid (US$): 177.00
Since it is 4-5 years old look to get less than half from the insurance co.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 07, 2009 | Orion STV2763 27" TV
Apex tv at2708s TV will come on by itself and will change channels on its own.
This is the common symptom of defected IC memory 24COxx,replaced this IC so it will works normal again.
Feel free to ask whatever the result...
Hope this may help you;
DON"T FORGET TO RATE:
Sep 07, 2008 | Apex Digital AT2708 27" TV
Pink screen
Anything is fixable just a matter of cost or availability of parts.
Jul 24, 2008 | Panasonic CT-27SL15 27" TV
Sharp 27" tv
You got the right idea,use the ext.imput on you tv and use the vcr to change the channels,you can check the solder conections in the tuner ,ussually the ground gets loose after a while but if you are not too familiar with tv service and dont want put any money in this set use your vcr.If the quality of the picture is still good then is worth keeping it.Let Us know if you need more information.
Oct 30, 2006 | Sharp 27C-240 27" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
