Question about NetGear WGR614 Wireless Router
How do I access my router? I type in http://10.0.0.1 and all I get is search results not the router itself. I have been able to do this in the past. Thanks
Posted by czbgoose on
Gaurav Kumar
  • 560 Answers
Anand Gupta
  • 1,272 Answers
I understand that you are unable to access the configuration page of the router WGR614. Please perform the below task on your computer connected to the router:
A. Click on Start then go to Programs and go to Accessories and open Command Prompt.
B. In Command Prompt window, type in 'ipconfig' and press 'Enter'. Note down the IP Address, Subnet mask & Default Gateway here.
Please try to access the configuration page of the router using the address that you got in the 'Default Gateway'.
Hope this allows you to resolve the issue. Please revert back for any further clarification.
Regards
Anand
Posted on May 19, 2011
Where is wps button?
About 49,500 results (0.39 seconds) Search Results
    What is WPS and how do I use it to set up the printer on the ...
    https://support.usa.canon.com/kb/index?page=content&id...
    Jan 15, 2016 - Use the , , and keys to select WLAN setup , then press the OK button. The printer will search for Access Points / Routers. If a WPS-compatible ...
    where is the WPS button? - Canon Community
    community.usa.canon.com/t5/Printer...Support/...WPS-button/td.../8893
    Dec 27, 2012 - Hello dmlarsen. The WPS button is not on the printer. This button would be located on your router itself. If your router does not have a clearly ...
    How to perform the wireless LAN setup using WPS connection
    support-th.canon-asia.com/contents/TH/EN/8200685600.html
    Dec 10, 2009 - Press and hold the WPS button on the access point (for about 5 ... If the Printer Connection screen appears instead of the screen above, the ... images for Printers & Copiers Where is wps button
Jan 23, 2016 | Office Equipment & Supplies
I can't find my WEP Key for the SB5101N Router. I tried the numbers located on the router itself, none of them have worked.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 14, 2011 | Arris SURFboard® SB5101 Cable Modem
My router reset itself and now is unsecure
You need to enable WEP security on router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jun 14, 2011 | D-Link DIR-615 Wireless Router
HOW DO I LOCK MY ROUTER
Locking the router can be done by setting a WEP key. Its a 10 digit alphanumeric key that you can set. Once you set it up, anyone who tries to access your router wirelessly will be prompted for that 10 digit key. Be sure to change your SSID (wireless network name) also so that you can distinguish your own secured wireless network from others.
SSID can be changed on the main setup page.
1. To access it, open Internet explorer while your computer is physically connected to the router.
2. Type http:\\192.168.1.1 (the default IP address of the router.) It will ask you for the username and password.
3. Enter the word "admin" for both username and password. It is the factory default username and password. On the main setup page, you will find the field for SSID or Network name.
4. Type your unique wireless network name and click the Save button on the bottom of the page.
5. On the router's web-based setup page, click the Wireless tab then click the Wireless Security sub-tab
6. Click the drop-down arrow for Security Mode and select WEP.
7. Under WEP Encryption select 64 bits 10 hex digits.
8. Enter a unique word in the Passphrase field, then click Generate.
9. The result will be a string of letters and numbers displayed in the space provided for Key 1.
NOTE: Take note of what is in Key 1. This key will serve as the wireless security password. Keep this key confidential.
10. Click the Save Settings button.
From now on, whenever anyone tries to access your wireless network, they need to enter Key 1 which you only know. There you go. Your wireless network is protected.
Nov 07, 2010 | Linksys (WIFILAPTOP) 802.11b Wireless...
I can't access my routers administration page. It tells me to type in http://192.168.0.1 and all I get is a bunch of search results instead of the administration page
disconnect your modem from router, or turn off your modem from router...
Now try to open...
because the router admin page will be built inside the router itself... so you never require internet connection to be ON for opening the router admin page...
Aug 02, 2010 | Computers & Internet
Which mobel router MC68EN360EM25C
I would be searching the Microsoft Knowledge Base for this answer. But 1st, I would look on the Motorola website for the answer.
NOTE: If the Router is physically connected to the Server (PC), via an Ethernet cable and you want to set it up, then
Either:
1. Check the manual for the IP No. of the Router (i,e., 10.1.1.1) and then type into your Browsers navigation field (http://).
OR,
1. Search Motorola's website for the IP No. for the Router model :
1.1 Navigate to http://www.motorola.com
1.2 Select where you want to go, for Consumers OR for Business
1.3 Click Support.
1.4 Click the Get Product Manuals link, from the Business Support section.
1.5 Type the Product description into the Search field. Press <Go>.
1.6 Download the product Manual and open it.
1.7 Find the area in the Manual where it tells you the IP No. of the Modem (to access the Modems Settings).
2. Then type it into your Browsers navigation field (http://).
This connects you to the Setup / Installation menu of the Modem Router itself and enables you to configure it's settings. Generally, you are able to access help from within this area.
I hope this helps. Regards,
Feb 09, 2010 | Motorola Computers & Internet
How to change router settings for BUffalo WCR-G54 wifi router? i can't access the URL: http://192.168.0.11.1 thanks!
This is actually wrong: http://192.168.0.11.1
If your router is connected to your computer via ethernet cable you will be able to get the configuration page of the router.
Windows XP
1. Click start
2. Click run
3. Type cmd in the box and press enter
4. On the black screen type ipconfig and press enter
5. Look for the default gateway
6. Copy that and use that to access the configuration page using the internet explorer
7. Open internet explorer, type http://the default gateway you copied in the address bar of the internet explorer
ex: http://192.168.1.0
Windows Vista
1. Click pearl button (start in xp)
2. Click on start search box (run in xp)
4. Right click the black icon up at the top
5. Click on run as administrator
6. Click on continue
7. On the black screen type ipconfig and press enter
8. Look for the default gateway
9. Copy that and use that to access the configuration page using the internet explorer
10. Open internet explorer, type http://the default gateway you copied in the address bar of the internet explorer
Jan 14, 2010 | Buffalo Technology WHR-G54S Wireless...
How to set up security password in the Netgear router?
Follow the steps to enable security on the wireless router:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Oct 01, 2009 | NetGear WGR614 Wireless Router
How do you extend the range of a Belkin N1 Vision router?
First connect your router to computer with ethenret cable.
http://192.168.15.1
If your rrouter is not access with this link then type in run "ipconfig /all"
then you get all adresese.
Gateway is ip adreese of yourt router so access it with those ip.
Type user name as "admin" and password as "blank or "admin" or "password"
then go to wi fi advanmced menu then change channel type 4,6 and 11
Try these 3 channel type 1 by 1 those give best result.
Set channel which give best result.
MAke sure when you set any settings in restart don't foget to save settings and restaret router .
Let me know if you need more assistanse.
Thanks.
Aug 27, 2009 | Belkin N1 Vision Router
NetGear WGR614 Wireless Router Logo
2,872 people viewed this question
Top NetGear Computers & Internet Experts
Mike
efs_perpends
efs_perpends
Lee Hodgson
Lee Hodgson
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
