Question about Lenovo IdeaCentre A600 3011 PC Desktop
How can i eject a stuck CD/DVD from disk drive of a levovo ideacentre A600? I didn't find any emergency-hole. please help.
Arvin Antonio Mercado
  • 384 Answers
Welcome to Fixya.
Try booting in BIOS mode by tapping on 'DEL' or 'F1' key as soon as you turn the computer on (while seeing the LENOVO screen). When in BIOS, you can eject the disc.
Thanks for using Fixya.
Posted on May 14, 2011
My CD is stuck in my Toshiba Satellite A505D laptop slot, with no hole near the Eject button.
Look on the cover on the tray near the eject button. Should be a tiny hole.
Get something like a straightened out paperclip and insert it in to the hole and push firmly but carefuly. It's an emergency eject for a stuck tray.
Feb 07, 2012 | Computers & Internet
Hello, my otiplex Gx620 cd/dvd drive will not eject the cd it in. Is there any way of releasing it ? many thanks hannah x
Hi and welcome to fixya!
Just follow these few steps and it should fix the problem (but if the problem keeps on happening, it maybe time to change the ODD).
    • 1 Locate the optical drive that contains your stuck disk. You'll see a small hole on or immediately below the disk tray.
    • 2 Straighten the paper clip.
    • 3 Insert the straight end of the paper clip in the hole and push. You should feel it catch inside the latch mechanism.
    • 4 Pull the paper clip out gently. The disk tray will come with it.
    • 5 Remove the CD or DVD and close the tray.
Read more: How to Eject a Stuck DVD/CD Drive ' eHow.com http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html#ixzz1RJn98iTa
Jul 06, 2011 | Dell for Optiplex GX620 CD-RW/DVD-ROM...
My disc won't eject and there's no hole for paperclip.
If your DVD Drive came with the computer originally your DVD Drive should have an emergency eject hole.
Kindly check the emergency eject hole just on top of the eject button you will see there a hole where you can poke using a paper clip.
May 29, 2011 | Dell Vostro 220 Desktop Computer
Acer aspire 5534 cd drive won't open
Hi
Open: My Computer, right click the CD/DVD Reader, and click: Eject.
If the CD/DVD didn't get out, so you need to use tall needle; to inject it in the hole besides the CD/DVD light.
Tacke care to inject the needle softly.
Please, Tell us your results.
Good Luck
May 15, 2011 | Computers & Internet
My lenovo ideacentre a600 wont stay on it cycles on then off on then off ect.
I have the same problem and still unsolved. However, I would like to notify mr. Hingee that this machine uses a dedicated mainboard (very neat I may add). Also in order to eject cd, touching the right bottom of screen will lit a menu and touhing the second one on the right will eject the cd.
Dec 01, 2010 | Lenovo 21.5 IdeaCentre A600 2.0 GHz Intel...
My pioneer dvdrw dvr 107d door wont open when i press button /have cd stuck inside (worked 5 mins ago) can still view dvd content/ will driver update fix ? please help
The drive may have come loose in your pc and is stopping the door to open.Hold open the front flap and press the eject button. If it wont eject your disk straighten out a paperclip and holding the front flap open look at the front of your drive and you will see a small hole.Push the paperclip through the hole and it will release the catch and eject your disk, You may have to push hard .Hope this helps you.
Regards Bill
May 04, 2010 | Pioneer DVR-107D DVD±RW Burner
Dell Studio - I can't get the DVD out of the drive. I can read the DVD but cannot remove it.
There is a small hole near the button you would push to eject the CD. Take a paper clip, and unwind it a bit. Stick it in that hole, and the CD should eject. Please let me know if you need further help.
Thanks
Mar 12, 2010 | Computers & Internet
I've a DELLXPS M1530. I'm trying to eject a CD, wont come out
I do believe that there is still a small hole by that slot, that you can insert a straightened paper Clip into, and keep pushing until you feel/hear a slight, click, keep pushing gently and the disk should soon appear. IF you cannot do that the DVD will be removable by taking out the fasteners underneath the laptop,, and sliding the DVD out. for repair of replacement.
Mar 04, 2010 | Dell XPS M1530 Laptop
My CD & DVD ROM drives will not open the door so I can insert a disk. The disk that is in the CD ROM that I can't get back out will play but the DVD ROM will not play anything at all.
Hello and Welcome to FixYa!
Your DVD rom tray may be stuck inside. Try the emergency eject by inserting a paper clip in the small hole at the front.
Regards,
Waqar
Dec 24, 2009 | Dell XPS 400 PC Desktop
My dvd is stuck in the CD Rom Drive thing
if the computer is powered off and the power chord deconnected, you can use a fine pin to 'poke' in the small hole in the front panel of the CD/DVD drive. this is the backup mechanism for when the regular opening mechanism fails. this way you can retrieve the disk that's blocked inside. after this you can try if it works as before again, but the possibility exists that you will have to replace the whole drive...
Jun 22, 2009 | Apple Computers & Internet
Lenovo IdeaCentre A600 3011  PC Desktop Logo
1,648 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
